Visual studio debug - pdb not loaded
Message 1 of 14
Hello, I have a problem with debuging from visual studio. All worked nice on Windows 7. I have new PC with Win 10 (same autocad same visual studio) and Iam unable to debug anything (even new "empty" project). When i started debug I get MgFoundation.pdb not loaded error. I tried to add MgFoundation.dll to references and it sas it's not "valid assembly or COM component". Please do you know where I can get working one?
Many thanks for any help
Replies (13)
Message 2 of 14
fieldguy
Can you attach a screen shot of your Project Properties->Application and Debug screens?  Maybe attach some code as well.  Maybe a screen shot of your references as well.
Message 3 of 14
It doesn't work even for clean new VB/C# project. But here they are.
Message 4 of 14
fieldguy
The only thing I can suggest is to try changing the path to the autocad apis.  It looks like you are using c:\autodesk\objectarx\inc.
I would try with the path to your autocad install folder.  Double check that copy local is false if you change them.
I am only quessing - it's hard to tell where the reference to "mgfoundation" is coming from.  I have the dll in the C:\Program Files\Autodesk\AutoCAD 2016\Map\bin\GisPlatform folder and have referenced the "OSGeo" apis several times but have never seen the warning for the "pdb" file.
Do you my chance have the "Map ObjectArx SDK" for your version?  What autocad vertical are you using?
Message 5 of 14
After some new tests I think that main problem is following.
This could be caused by our proxy company policy. Is there a way to setup proxy in VS or better download this symbols manually
Message 6 of 14
fieldguy
Sorry - I have no idea where "mgfoundation" is coming from.  Unless you post code that will build and duplicate the error I cannot help you.
Message 7 of 14
fieldguy
1 more guess.  Copy the target portion of your desktop icon and paste it in the "command line arguments" box.  You have to edit it to remove the portion already in the "start" box.
Message 8 of 14
I tried last thing with "command line arguments" and still same error. Also I added zip with whole solution. Now I dont know if is error in autocad or VS.
Message 9 of 14
fieldguy
>>this<< is the answer
uncheck "Enable native code debugging"
Message 10 of 14
Thanks for advice. I allready tried this and if I turn of "Enable native code debugging" then autocad crash before start. (autocad stoepd working debug / close)
Message 11 of 14
fieldguy
Did you try "Enable Just My Code" as well?
>>link<<
Message 12 of 14
I Just tested all combinations of "Native code debugging" and "Enable just my code". Thinking that problem will be in communication with Microsoft symbol servers.
Message 13 of 14
fieldguy
I am out of ideas.  Your test project worked for me in win 10 and civil 3d 2016.
Message 14 of 14
Thanks for your help and time. I will try to look closely on that HTTP error with microsoft symbol server.
btw I have folowing systems:
Windows 10 Enterprise
Autodesk AutoCAD Map 3D 2017
Visual studio 2015
