AutoCAD Map 3D Developer
Welcome to Autodesk’s AutoCAD Map 3D Developer Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D Developer topics.
vb.net - Topobase - draw area of display-model
3 REPLIES 3
jan_tappenbeck
656 Views, 3 Replies
Hi!
i restart my posting of https://forums.autodesk.com/t5/net/vb-net-topobase-draw-area-of-display-model/td-p/7235171 in this Group again.
after add the code of drewbb my code looks like:
 Public Sub DrawDM(Document As Autodesk.Map.IM.Forms.Document, Optional ByVal Silent As Boolean = True)
        Dim DM_Name As String = "O:\Map2015-Darstellungsmodelle\ALKIS 20170125\ALKIS für DWG.tbdm"
        Dim Msg As String = ""
        Dim acDocMgr As DocumentCollection = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager
        Dim acDoc As Autodesk.AutoCAD.ApplicationServices.Document = acDocMgr.MdiActiveDocument
        Dim extents2d As Autodesk.AutoCAD.DatabaseServices.Extents2d = _AcadSrv.GetCurrentViewBound()
        If System.IO.File.Exists(DM_Name) = False Then
            If Silent = False Then
                MsgBox("Darstellungsmodell nicht gefunden!", MsgBoxStyle.Critical, k_AppName_Vermessung)
            Exit Sub
        If IsNothing(Document) Then
                MsgBox("Es ist kein Dokument zugewiesen!", MsgBoxStyle.Critical, k_AppName_Vermessung)
            Exit Sub
        Dim graphicsGenerator As Autodesk.Map.IM.Display.GraphicsGeneration.IGraphicsGenerator
        Try
            graphicsGenerator = Document.Application.Services.GetService(Of Autodesk.Map.IM.Display.GraphicsGeneration.IGraphicsGenerator)()
            'Bildaufbau
            Dim filterSetter As IFilterSetter = FilterSetterFactory.Create(graphicsGenerator.DisplayModel)
            filterSetter.OnlyOnTopobaseLayers = True
            filterSetter.TransformCoordSysInFilter = True
            Dim polygon = New Autodesk.Map.IM.Graphic.Polygon() From { _
                New Autodesk.Map.IM.Graphic.LinePoint(extents2d.MinPoint.X, extents2d.MinPoint.Y), _
                New Autodesk.Map.IM.Graphic.LinePoint(extents2d.MaxPoint.X, extents2d.MinPoint.Y), _
                New Autodesk.Map.IM.Graphic.LinePoint(extents2d.MaxPoint.X, extents2d.MaxPoint.Y), _
                New Autodesk.Map.IM.Graphic.LinePoint(extents2d.MinPoint.X, extents2d.MaxPoint.Y), _
                New Autodesk.Map.IM.Graphic.LinePoint(extents2d.MinPoint.X, extents2d.MinPoint.Y) _
            filterSetter.ApplyViewport(polygon)
            Dim displayRepository As Autodesk.Map.IM.Display.DisplayModelManagement.IDisplayModelRepository
            displayRepository = graphicsGenerator.DisplayModelRepository
            Dim RepositoryPath As String
            RepositoryPath = graphicsGenerator.DisplayModelRepository.RepositoryDirectory.ToString()
            graphicsGenerator.DisplayModel = displayRepository.Load(DM_Name)
            'graphicsGenerator.DisplayModel = displayRepository.Load(RepositoryPath + "\" + "MeinDarstellungsmodell.tbdm")
            graphicsGenerator.ShowProgressBar = True
            Dim mydocuments As System.Collections.Generic.ICollection(Of Autodesk.Map.IM.Display.GraphicsGeneration.IDocument)
            'acDoc As Autodesk.AutoCAD.ApplicationServices.Document
            Dim docLock As DocumentLock = acDoc.LockDocument
            Using docLock
                mydocuments = graphicsGenerator.Draw
            End Using
        Catch ex As Exception
            Dim TryReport As New EBL.Service.TryCatchReport
            TryReport.Show("unerwarteter Fehler in EBL.Import.SielVerm > VermSielPunktImport", ex.ToString)
        Finally
            graphicsGenerator.ShowProgressBar = False
        End Try
    End Sub
GetCurrentViewBound is a function to generate the min/max-coord of the current Screen. this works correct.
if i start my function it draw everytime the complete DM ! for the draw-process the screen zoom automatically to limit.
could someone help?
regards Jan
3 REPLIES 3
in reply to: jan_tappenbeck
Hi Jan,
just a guess - load the DM before you apply the filter.
Rob
jan_tappenbeck
Dear Robert,
thanks - but i did not understand ... complete -
i try following - but without success !
        Try
            Select Case SelectionStatus
                Case Opt_CScreen 'BildSchirm
                    extents2d = _AcadSrv.GetCurrentViewBound()
i move some lines to more to the top.
(auf gut deutsch - ich hab es nicht ganz verstanden und try&error hat nicht geklappt!)
could you give a tip to me?
regards Jan
hi !
here the complete working source:
        Dim SelectionStatus As String = "NONE"
        Dim Opt_Exit As String = "Ende"
        Dim Opt_All As String = "Alles"
        Dim Opt_CScreen As String = "Bildschirm"
        Dim Opt_Window As String = "Fenster"
        Dim Opt_Yes As String = "Ja"
        Dim Opt_No As String = "Nein"
        Reinit()
        Dim extents2d As Autodesk.AutoCAD.DatabaseServices.Extents2d = Nothing
            Exit Sub
            Exit Sub
        Dim opt0 As New Autodesk.AutoCAD.EditorInput.PromptKeywordOptions(vbLf & "Select an entity:")
        opt0.AllowNone = True
        opt0.Keywords.Add(Opt_All)
        opt0.Keywords.Add(Opt_CScreen)
        opt0.Keywords.Add(Opt_Window)
        opt0.Keywords.Add("Ende")
        opt0.Keywords.[Default] = Opt_Window
        ' ausblenden einer Option in der []-Liste - index nullbasiert
        'opt0.Keywords(2).Visible = False
        While True
            Dim res0 As Autodesk.AutoCAD.EditorInput.PromptResult = _Editor.GetKeywords(opt0)
            If res0.Status = Autodesk.AutoCAD.EditorInput.PromptStatus.OK Then
                ' hier muss keine Prüfung auf unzulässige Begriffe erfolgen.
                SelectionStatus = res0.StringResult
                Exit While
            Else
                Exit Sub
        End While
        ' Nachfrage, wenn aktuell ein Darstellungsmodell gelanden ist.
        If IsDMLoaded() = True Then
            Dim opt1 As New Autodesk.AutoCAD.EditorInput.PromptKeywordOptions(vbLf & "Soll das aktuelle Darstellungsmodell gelöscht werden:")
            opt1.AllowNone = True
            opt1.Keywords.Add(Opt_Yes)
            opt1.Keywords.Add(Opt_No)
            opt1.Keywords.Add(Opt_Exit)
            opt1.Keywords.[Default] = Opt_Yes
            Dim res1 As Autodesk.AutoCAD.EditorInput.PromptResult = _Editor.GetKeywords(opt1)
            If res1.Status = Autodesk.AutoCAD.EditorInput.PromptStatus.OK Then
                Select Case res1.StringResult
                    Case Opt_Yes
                        MsgBox("Layer löschen")
                    Case Opt_Exit
                        Exit Sub
                End Select
            Else
                Exit Sub
        Try
                Case Opt_Window
                    extents2d = _AcadSrv.GetWindowCorner()
                    If IsNothing(extents2d) Then
                        _Editor.WriteMessage(vbCrLf & "KEIN Fenster gewählt! - Funktion wurde abgebrochen.")
            End Select
            If Not IsNothing(extents2d) Then
            Dim docLock As DocumentLock = _AcDocument.LockDocument
            Using docLock
            End Using
            _MiscSrv.ZoomVorher() ' Ansicht wiederherstellen
        Finally
        End Try
    End Sub
Jan
Technology Administrators
AutoCAD Beta
