AutoCAD Map 3D Developer
Welcome to Autodesk’s AutoCAD Map 3D Developer Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D Developer topics.
SHP Import Locking .shp file
4 REPLIES 4
mordend
727 Views, 4 Replies
I want to be able to delete the .shp after importing it.
Attached code works but it leaves the .shp as read only until CAD closes. Am I missing something?
private void ImportShape(FileInfo file)
            Stopwatch sw = new Stopwatch();
            sw.Start();
            MapApplication mapApp = HostMapApplicationServices.Application;
            using (Importer importer = mapApp.Importer)
                importer.Init("SHP", file.FullName);
                string fileName = Path.GetFileNameWithoutExtension(file.FullName).Replace(" ", "");
                foreach (InputLayer inputLayer in importer)
                    inputLayer.SetLayerName(LayerNameType.LayerNameDirect, fileName);
                    inputLayer.SetDataMapping(ImportDataMapping.NewObjectDataOnly, fileName);
                    inputLayer.Dispose();
                importer.ImportPolygonsAsClosedPolylines = true;
                ImportResults result = importer.Import(true);
                sw.Stop();
                Quest_Common.ed.WriteMessage(string.Format("\n{0} object(s) imported in {1} sec(s)", result.EntitiesImported.ToString(), sw.Elapsed.Seconds));
                importer.Dispose();
            file.Delete();
4 REPLIES 4
Alfred.NESWADBA
in reply to: mordend
have not tried your code, but see one issue with that:
If you use the using statement like that
then do not call
importer.Dispose()
 Because using(.....){...} includes importer.Dispose at the end of {...}
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
norman.yuan
AFAIK, this has been a known issue for years, but I have not tried to see if it is fixed in later version after AutoCAD Map/Civil 2015.
Norman Yuan
Drive CAD With Code
mordend
in reply to: Alfred.NESWADBA
I'm aware that the using statement calls dispose when it's closed, and that is the point of it.
I had it in there to see if it made any difference. But thank you for pointing it out.
mordend
in reply to: norman.yuan
So testing in 2017 it is still an issue.
But good news is that it seems to be fixed in 2020. YAY!!!
Thanks Norman.
Technology Administrators
AutoCAD Beta
