Random block insertion into defined area
Hi!
Is there a command or lisp to randomly insert certain blocks (eg. trees) into polyline defined area ? So I select some area defined with polyline and then I want to insert into that area randomly lots of tree blocks (or whatever blocks).
Tried to google but didn't find anything useful.
Any ideas ? Smiley Happy
M.
Alfred.NESWADBA
I did something like that with the following principle steps:
  • get bounding box of the polygon
  • for x = boundingbox.min.x to boundingbox.max.x by your x-stepsize
  •    for y = boundingbox.min.y to boundingbox.max.y by your y-stepsize
  •        here is a new xy-coordinate (like that of an array command)
  •        xnew = x + random value (within a tolerance to the left/right, positive or negative)
  •        ynew = y + random value (within a tolerance to the left/right, positive or negative)
  •        that coordinate xnew/ynew is now more randomized, depending on a higher or lower tolerance value it look more like an array or more randomized
  •        check if that new coordinate is inside the polygon
  •        if yes ==> that's a new point
  •    next y
  • next x
HTH, - alfred -
Alfred NESWADBA
(not an Autodesk consultant)
1. Insert one block
2. Use array to multiply the entire area
3. Use MAPCLEAN.Select objects / Duplicates / Desired minimum distance
4. Use MAPTRIM. Select Boundary/Select Objects/Trim Outside Boundary
