Hi everyone.
Could someone please help me.
I need to make a new feature from a polyline using C#.NET.
I'm used to autolisp programing and new to .NET.
So far I managed to get a ss set of polylines that I need and get the area and parcel number (mtext) inside the polyline.
Now I need to make a new feature from the polyline geometry in the OBData Table (.sdf) and fill the table with the values "area" and "parcel number".
using System; using System.Collections.Generic; using System.Linq; using System.Text; using System.Threading.Tasks; using Autodesk.AutoCAD.Runtime; using Autodesk.AutoCAD.ApplicationServices; using Autodesk.AutoCAD.DatabaseServices; using Autodesk.AutoCAD.EditorInput; using Autodesk.AutoCAD.Geometry; [assembly: CommandClass(typeof(AC1.Class1))] namespace AC1 { public class Class1 { [CommandMethod("PP")] public static void FilterSelectionSet() { // Open the doc and get the current document editor Document acDoc = Application.DocumentManager.MdiActiveDocument; Editor acDocEd = Application.DocumentManager.MdiActiveDocument.Editor; Database acCurDb = acDoc.Database; /////////////////////// SSET 1 ///////////////////////////////// // Create a TypedValue array to define the filter criteria TypedValue[] acTypValAr = new TypedValue[2]; acTypValAr.SetValue(new TypedValue((int)DxfCode.LayerName, "0"), 0); acTypValAr.SetValue(new TypedValue((int)DxfCode.Start, "LWPOLYLINE"), 1); // Assign the filter criteria to a SelectionFilter object SelectionFilter acSelFtr = new SelectionFilter(acTypValAr); PromptSelectionResult psr = acDocEd.SelectAll(acSelFtr); SelectionSet acSet = psr.Value; //acDocEd.WriteMessage("Number of selected entities is {0}.", acSet.Count.ToString()); //______________________________________________________________________ //Start transaction and read ObjectId using (Transaction acTrans = acCurDb.TransactionManager.StartTransaction()) { // Open the Block table for read BlockTable acBlkTbl; acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead) as BlockTable; // Open the Block table record Model space for read BlockTableRecord acBlkTblRec; acBlkTblRec = acTrans.GetObject(acBlkTbl[BlockTableRecord.ModelSpace], OpenMode.ForRead) as BlockTableRecord; ObjectId[] idcoll = acSet.GetObjectIds(); foreach (ObjectId mt in idcoll) { DBObject obj = acTrans.GetObject(mt,OpenMode.ForRead); Polyline lwp = obj as Polyline; double area = lwp.Area; acDoc.Editor.WriteMessage("\nArea :" + area.ToString()); Point3dCollection pt3d = new Point3dCollection(); for (int nCnt = 0; nCnt < lwp.NumberOfVertices; nCnt++) { pt3d.Add(lwp.GetPoint3dAt(nCnt)); } ////////////////////// SSET 2 ////////////////////////////////// // Create a TypedValue array to define the filter criteria TypedValue[] acTypValAr1 = new TypedValue[1]; acTypValAr1.SetValue(new TypedValue((int)DxfCode.Start, "MText"), 0); // Assign the filter criteria to a SelectionFilter object SelectionFilter acSelFtr1 = new SelectionFilter(acTypValAr1); PromptSelectionResult psr1 = acDocEd.SelectWindowPolygon(pt3d, acSelFtr1); SelectionSet acSet1 = psr1.Value; //______________________________________________________________________ ObjectId[] idmtxt = acSet1.GetObjectIds(); int mtcoll = idmtxt.Length; foreach (ObjectId mtid in idmtxt) { DBObject obj1 = acTrans.GetObject(mtid, OpenMode.ForRead); MText mtxt1 = obj1 as MText; string mtext1 = mtxt1.Text; acDoc.Editor.WriteMessage("\nMText:" + mtext1); } if (lwp != null) { // Use a for loop to get each vertex, one by one int vn = lwp.NumberOfVertices; acDoc.Editor.WriteMessage("\nNumber of vertices:" + vn.ToString()); for (int i = 0; i < vn; i++) { // Could also get the 3D point here Point2d pt = lwp.GetPoint2dAt(i); List<Point2d> pts = new List<Point2d> { }; pts.Add(pt); double ptX = pt.X; double ptY = pt.Y; //List<double> ptss = new List<double> {}; //ptss.Add(pt.); //ptss.Add(pt.ToArray); // acDoc.Editor.WriteMessage("\nVertex :" + string.Format("{0}", i) + pt.ToString()); // acDoc.Editor.WriteMessage("\nVertex X :" + ptX.ToString()); // acDoc.Editor.WriteMessage("\nVertex Y :" + ptY.ToString()); } } } } } } }
Solved by hence_the_name. Go to Solution.
if you are new to .net then you are also new to Map FDO API as it is not available for Lisp.
You will find tutorials for Map FDO .net API - here is one link:
http://adndevblog.typepad.com/infrastructure/2013/02/autocad-map-3d-api-training-content-part-1.html
Map SDK used to come with Developer samples - one sample covers your question - have a look:
...\Map ObjectARX SDK 2013\Map Samples\Platform\Bridge\Bridge.csproj
This sample demonstrates:
- How to convert AcDbEntity to MgGeometry, and add to layer as a feature.
- How to convert MgGeometry to AcDbEntity, and delete the feautre from layer
Good luck, Rob
Thank you very much for your kind response. I will check the sample and tutorials.
