AutoCAD Map 3D Developer
Welcome to Autodesk’s AutoCAD Map 3D Developer Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D Developer topics.
MAPCREATEFEATUREFROMGEOMETRY
2 REPLIES 2
svucic
280 Views, 2 Replies
Hi everyone.
Could someone please help me.
I need to make a new feature from a polyline using C#.NET.
I'm used to autolisp programing and new to .NET.
So far I managed to get a ss set of polylines that I need and get the area and parcel number (mtext) inside the polyline.
Now I need to make a new feature from the polyline geometry in the OBData Table (.sdf) and fill the table with the values "area" and "parcel number".
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Geometry;
[assembly: CommandClass(typeof(AC1.Class1))]
namespace AC1
    public class Class1
        [CommandMethod("PP")]
        public static void FilterSelectionSet()
            // Open the doc and get the current document editor
            Document acDoc = Application.DocumentManager.MdiActiveDocument;
            Editor acDocEd = Application.DocumentManager.MdiActiveDocument.Editor;
            Database acCurDb = acDoc.Database;
            /////////////////////// SSET 1 /////////////////////////////////
            // Create a TypedValue array to define the filter criteria
            TypedValue[] acTypValAr = new TypedValue[2];
            acTypValAr.SetValue(new TypedValue((int)DxfCode.LayerName, "0"), 0);
            acTypValAr.SetValue(new TypedValue((int)DxfCode.Start, "LWPOLYLINE"), 1);
            // Assign the filter criteria to a SelectionFilter object
            SelectionFilter acSelFtr = new SelectionFilter(acTypValAr);
            PromptSelectionResult psr = acDocEd.SelectAll(acSelFtr);
            SelectionSet acSet = psr.Value;
            //acDocEd.WriteMessage("Number of selected entities is {0}.", acSet.Count.ToString());
            //______________________________________________________________________
            //Start transaction and read ObjectId
            using (Transaction acTrans = acCurDb.TransactionManager.StartTransaction())
                // Open the Block table for read
                BlockTable acBlkTbl;
                acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId,
                OpenMode.ForRead) as BlockTable;
                // Open the Block table record Model space for read
                BlockTableRecord acBlkTblRec;
                acBlkTblRec = acTrans.GetObject(acBlkTbl[BlockTableRecord.ModelSpace],
                OpenMode.ForRead) as BlockTableRecord;
                ObjectId[] idcoll = acSet.GetObjectIds();
                foreach (ObjectId mt in idcoll)
                    DBObject obj = acTrans.GetObject(mt,OpenMode.ForRead);
                    Polyline lwp = obj as Polyline;
                    double area = lwp.Area;
                    acDoc.Editor.WriteMessage("\nArea :" + area.ToString());
                    Point3dCollection pt3d = new Point3dCollection();
                    for (int nCnt = 0; nCnt < lwp.NumberOfVertices; nCnt++)
                        pt3d.Add(lwp.GetPoint3dAt(nCnt));
                    ////////////////////// SSET 2 //////////////////////////////////
                    TypedValue[] acTypValAr1 = new TypedValue[1];
                    acTypValAr1.SetValue(new TypedValue((int)DxfCode.Start, "MText"), 0);
                    SelectionFilter acSelFtr1 = new SelectionFilter(acTypValAr1);
                    PromptSelectionResult psr1 = acDocEd.SelectWindowPolygon(pt3d, acSelFtr1);
                    SelectionSet acSet1 = psr1.Value;
                    ObjectId[] idmtxt = acSet1.GetObjectIds();
                    int mtcoll = idmtxt.Length;
                    foreach (ObjectId mtid in idmtxt)
                        DBObject obj1 = acTrans.GetObject(mtid, OpenMode.ForRead);
                        MText mtxt1 = obj1 as MText;
                        string mtext1 = mtxt1.Text;
                        acDoc.Editor.WriteMessage("\nMText:" + mtext1);
                    if (lwp != null)
                        // Use a for loop to get each vertex, one by one
                        int vn = lwp.NumberOfVertices;
                        acDoc.Editor.WriteMessage("\nNumber of vertices:" + vn.ToString());
                        for (int i = 0; i < vn; i++)
                            // Could also get the 3D point here
                            Point2d pt = lwp.GetPoint2dAt(i);
                            List<Point2d> pts = new List<Point2d> { };
                            pts.Add(pt);
                            double ptX = pt.X;
                            double ptY = pt.Y;
                            //List<double> ptss = new List<double> {};
                            //ptss.Add(pt.);
                            //ptss.Add(pt.ToArray);
                           // acDoc.Editor.WriteMessage("\nVertex :" + string.Format("{0}", i) + pt.ToString());
                           // acDoc.Editor.WriteMessage("\nVertex X :" + ptX.ToString());
                           // acDoc.Editor.WriteMessage("\nVertex Y :" + ptY.ToString());
2 REPLIES 2
hence_the_name
in reply to: svucic
if you are new to .net then you are also new to Map FDO API as it is not available for Lisp.
You will find tutorials for Map FDO .net API - here is one link:
http://adndevblog.typepad.com/infrastructure/2013/02/autocad-map-3d-api-training-content-part-1.html
Map SDK used to come with Developer samples - one sample covers your question - have a look:
...\Map ObjectARX SDK 2013\Map Samples\Platform\Bridge\Bridge.csproj
This sample demonstrates:
-   How to convert AcDbEntity to MgGeometry, and add to layer as a feature.
-   How to convert MgGeometry to AcDbEntity, and delete the feautre from layer
Good luck, Rob
http://raumpatrouille3d.blogspot.ch/
svucic
in reply to: hence_the_name
Thank you very much for your kind response. I will check the sample and tutorials.
”Boost
