I have a Polyline with OD having UniqueTag (ID) for the polyline. Inside the polyline there is also a BlockReference (like a tag to show visual location) which has additional attributes along with UniqueTag.
From .NET C# I am able to read the vertices for polyline and BlockReference Attributes individually. But I am unable to read the UniqueTag (OD:Object Data) in polyline or establish any connection between BlockReference and Polyline. We need to send the vertices and UniqueTag of the polyline to a Geospatial server to render the map in UI.
I am looking for either of the below two options:
1. How to read Object Data or its property from a Polyline ?
I have seen some code which uses Autodesk.Gis.Map.ObjectData but its giving compiler error as my ObjectARX_2017 do not have this api anymore. We are using Autocad Map 3D 2017.
2. Is it possible locate BlockReference within the polyline and identify the Attributes of Block and tag them to the polyline ?
Please suggest if any better alternate options. Thanks in advance.
Sri
