load Sdf
load Sdf
load Sdf
i save data by cliping as SDF in starting the first cad map,then i start another cad map to  load the SDF。but sdf can not be loaded in the second cad ,it only was loaded in the first cad.
It appears to me, information provided here is little insufficient to conclude what is going on at your side.
Would you elaborate the issue with steps you follow ? Do you use any API here or all the steps you try using Map 3D UI tools / commands only ?
Partha Sarkar
