For me with my tools I make this: it use 2 lisp.
At the first time I use Properties2OD.lsp (generic) and select only LAYER for input data
In second time I use this (it's adapted for the exemple in the link: "EXAMPLE OBJECT DATA _A_ version 2007.dwg")
And delete the table create by the first lisp.
(defun c:transfert_OD ( / js in n obj tbllist)
(setq js
(ssget
(list
(cons 67 (if (eq (getvar "CVPORT") 1) 1 0))
(cons 410 (if (eq (getvar "CVPORT") 1) (getvar "CTAB") "Model"))
(cond
(js
(setq in
("TBL_AcDbPolyline" . "LAYER")
("A" . "CODE")
(repeat (setq n (sslength js))
(setq obj (ssname js (setq n (1- n))))
(setq tbllist (ade_odgettables obj))
(cond
(tbllist
(foreach tbl (mapcar 'car in)
(cond
((not (member tbl tbllist))
(ssdel obj js)
(T (ssdel obj js))
(cond
(js
(ade_odsetfield obj
(car (nth 1 in))
(cdr (nth 1 in))
0
(atoi
(ade_odgetfield obj
(car (nth 0 in))
(cdr (nth 0 in))
0
(sssetfirst nil js)
(princ (strcat "\n" (itoa (sslength js)) " entités ont subit des transferts d'OD de " (car (nth 0 in)) " vers " (car (nth 1 in))))
(prin1)
NB:
In this I must adapt the list for transfering data
'(("TBL_AcDbPolyline" . "LAYER") ("A" . "CODE"))
and for convert the string of layer to integer for the CODE I add (atoi) for (ade_odgetfield obj (car (nth 0 in)) (cdr (nth 0 in)) 0) because the type of data is not the same.
