Announcements
Invoke comands with "internal names" from AutoCAD?
Peter2_1
Peter2_1
IM, oracle
In the forms there are some buttons to select / highlight the current object or all current filtered objects. Fine.
There is also a button to "unhighlight" the objects. Also fine.
Sometimes I close all my forms / windows and forget to "unhighlight"  - not fine.
The internal name of the command is "Autodesk.Map.IM.Map.MapDialog/TBUnhighlightAll"
Is there a way to call it from AutoCAD/MAP CUI?
AutoCAD Map 3D 2023 German / Oracle
urs_sommerhalder
Why not use the command in german AutoCAD Map 3D "rg" ("regen")?
Regards #Urs
Peter2_1
Thanks Urs,
for the comment, but "regen" shows a special behaviour for me (Map 2018). It "unhighlights" the objects, but they are not removed from the "highligthing-list".
Example:
- select some "sections"
- open the form with "tbattributes"
- play around with "mark all objects in selection set / unmark them": they are switched on/off as expected
- "mark all objects"
- type "regen": the highlight goes away
- but: move your mouse over the sections -> they are permanently highlighted just by moving around (without clicks)
- "unmark all objects" -> mouse moving has only expected effects
urs_sommerhalder
Hi @Peter2_1 ,
Thank you for detailed description, now i can reprduce the effect aso in AutoCAD Map 3D 2020.
Possible solutions are:
- Open another Form and click the "unhighlight" button
- Regenerate Graphic (TBGENERATEGRAPHIC)- Refresh single layer in display manager
- Refresh all layers in display manager wihth command "MAPDISPLAYMANAGER A B " (command in german for AutoCAD Map 3D)
- Develop a document plugin for AutoCAD Map 3D for unhighlight all features in graphic
I have not found a command for invoke the internal functions directly in the AutoCAD command line, only with a AutoCAD or AutoCAD Map 3D plugin.
I hope its help...
Regards #Urs
Peter2_1
Thanks Urs
unfortunately the coding of a plugin is not possible for everybody (better: beyond the average user knowledge) ...
Basically, it would be great if some of the commands, hidden in forms or subforms or contextmenu of submenu, could be reached easy in a toolbar or with a shortcut or with an additional "keyboard-for-special-usage" or something else ....
