AutoCAD Map 3D Developer
Welcome to Autodesk’s AutoCAD Map 3D Developer Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D Developer topics.
Interface probleme Autocad 2014 3d map
3 REPLIES 3
513 Views, 3 Replies
Hi i have a problem with Autocad interface the top bottom its white have some idea what is the problem ?
3 REPLIES 3
Alfred.NESWADBA
which operating system are you on?
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
in reply to: Alfred.NESWADBA
Windows 10 Profesional
Alfred.NESWADBA
Well, that's most probably the source of your issue, AutoCAD 2014 (and so all verticals like Map3D) are not compatible with Windows 10.
You might try run AutoCAD Map 3D in compatibility mode (>>>more info's<<<).
If you don't want to update (and as we are expecting more updates for Windows 10) think about creating a virtual system based on Windows 7 and running AutoCAD in that mode.
- alfred -
Alfred NESWADBA
Technology Administrators
AutoCAD Beta
