Hi
I was try to add file to startup suite
if I have one file there then this works I see the file I add but not if I add new file for first time then Autocad clear Regestry
when I open APPLOAD
is it not possible to add file to Regestry startup suite with VB.NET
I work on sample from https://www.theswamp.org
Dim regKey As RegistryKey regKey = My.Computer.Registry.CurrentUser.OpenSubKey("Software\Autodesk\AutoCAD\R20.0\ACAD-E002:409\Profiles\", True) Dim Profiles() = regKey.GetSubKeyNames For Each Profiles_subfolder In Profiles Dim Profile_subfolder As RegistryKey = regKey.OpenSubKey(Profiles_subfolder + "\" + "Dialogs\Appload\Startup\", RegistryKeyPermissionCheck.ReadWriteSubTree) Dim NUMBER As String = Profile_subfolder.GetValue("NumStartup").ToString Profile_subfolder.SetValue("NumStartup", (CInt(NUMBER) + 1).ToString) Profile_subfolder.SetValue((CInt(NUMBER) + 1).ToString + "Startup", "C:\Users\Sigster_pc\Downloads\ConvertNet2\te.lsp") Next Profiles_subfolder
Found out I need to exit Autocad then this is ok I can Add the file
are any change I can add the file when Autocad is running
