Since few weeks ago, I noticed that when I try to debug an .NET command from Visual Studio Express 2012 for Windows Desktop, AutoCAD gives me a fatal error and exists when it is loading (even before netloading the command).
I also tryed to start AutoCAD manually and do debug by attaching to the process, but that way AutoCAD Freezes and I have to kill the process (even if I dettach the process and stop debugging).
This is what I have:
Has anyone had this problem? How could I solve it?
Thanks for your help in advance!
Solved by Alfred.NESWADBA. Go to Solution.
Maybe that helps (look to Brigitte's solution >>>click<<<
- alfred -
WOW!! That solved it!
In my case MAP 2014 has different file structure so I had to look for the ".res" file to copy it. After the change, all is OK now.
Tanks!!!!!
