Recently upgraded to 2017 from 2014. I utilize a map import daily. Normally I can use the commands "erase" "all" then I "remove" the objects or area that I want to work within. In 2014 this was a quick process. In 2017 after typing remove, the screen freezes & I am unable to select an area to remove from the map.
Thank you,
Melissa
