The title is self explanatory, but I'm trying to convert an entity name to a string to order alphabetically and convert back to the original status. ;(acad_strlsort (nth x alisp))
This is a work around of course.
Any help would be much appreciated. Thanks in advance.
Michael Luckett
(defun sort_ename ()
(setq x 0 strlis '()); Becomes the same as alisp in string format
(repeat (length alisp)
(setq g 0 tmplis '())
(setq itm (nth x alisp))
(repeat (length itm)
(setq val (EntToStr (nth g itm)))
(setq tmplis (append tmplis (list val)))
(setq g (+ g 1))
(setq strlis (append strlis (list tmplis)))
(setq x (+ x 1))
(setq x 0 sortlis '());Sorts in alphabetical order
(repeat (length strlis)
(setq itm (nth x strlis))
(setq nitm (acad_strlsort itm))
(setq sortlis (append sortlis (list nitm)))
(setq x (+ x 1))
(setq x 0 totlis '()); Final list of Entities
(setq tval (nth x alisp))
(setq itm2 (nth x sortlis))
(setq g 0 nalis '())
(repeat (length itm2)
(setq val (nth g itm2))
(setq h 0)
(setq val2 (nth h itm))
(setq tval2 (nth h tval))
(if (= val val2)(setq nalis (append nalis (list tval2))))
(setq h (+ h 1))
(setq g (+ g 1))
(setq totlis (append totlis (list nalis)))
(setq x (+ x 1))
(princ)
;https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/convert-ename-to-string/td-p/795663
(defun EntToStr (ent / curstr opnfil)
(if (and ent (setq opnfil (open "EntToStr.tmp" "w")))
(progn
(princ ent opnfil)
(close opnfil)
(setq opnfil (open "EntToStr.tmp" "r")
curstr (read-line opnfil)
(close opnfil)
curstr
nil
Unconventional, but effective. See citation above for the sub "EntToStr ". "Alisp" is the list of entities.
Michael Luckett
