AutoCAD Map 3D Developer
Welcome to Autodesk’s AutoCAD Map 3D Developer Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D Developer topics.
Connect Autocad to Smartsheet using c#
0 ANTWORTEN 0
Nachricht 1 von 1
dwattersQJ39E
133 Aufrufe, 0 Antworten
I am attempting to connect to a smartsheet using their API in a C# program for autocad / autocadMap3d.
i am getting the error : "could not load file or assembly 'smartsheet-csharp-sdk' or one of its dependencies.
System.IO.FileNotFoundException: Could not load file or assembly 'smartsheet-csharp-sdk, Version=5.0.0.0, Culture=neutral, PublicKeyToken=null' or one of its dependencies. The system cannot find the file specified.
File name: 'smartsheet-csharp-sdk, Version=5.0.0.0, Culture=neutral, PublicKeyToken=null'
Looking for anyone who has had experience with smartsheets or trying to link other APIs in an autocad program.
        public static void InitializeSmartsheetClient()
            Document doc = Application.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Editor ed = doc.Editor;
            string smartsheetAccessToken = ""; // token
            long specificSheetId = ;  // Smartsheet Tracker
            try
                // Initialize Smartsheet client with the API access token using SmartsheetBuilder
                var smartsheetClient = new SmartsheetBuilder()
                                 .SetAccessToken(smartsheetAccessToken)
                                 .Build(); // This initializes the SmartsheetClient
                // Retrieve the sheet by its ID from Smartsheet
                var sheet = smartsheetClient.SheetResources.GetSheet(specificSheetId, null, null);  // Retrieve the sheet by ID
                // If the sheet is retrieved successfully, display the sheet name
                ed.WriteMessage($"\nConnected to Smartsheet! Sheet Name: {sheet.Name}\n");
            catch (System.Exception ex)
                // If there’s an error connecting to Smartsheet, display the error message
                ed.WriteMessage($"\nError connecting to Smartsheet: {ex.Message}\n");
0 ANTWORTEN 0
