Working with ImpEntity
Message 1 of 8
How do I go about working with ImpEntity objects that are inserted via FDO?
I'd like to get some attribute information from them.
I'm using Map 2008 and .Net 2.0.
-Anthony
Replies (7)
Message 2 of 8
You need to use the FDO API, there are some samples in the toolkit that may
point you in the right direction.
Murph
The world is not FLAT so why is your GIS data?
http://map3d.wordpress.com
"Anthony" wrote in message
news:5672472@discussion.autodesk.com...
-Anthony
Message 3 of 8
Please can you tell me what FDO API example helps with ImpEntity?? Or post some code in C# to use that class??
I was trying to do that and work with the data table using C# but I can't find a guide...
I would like to use the Data inside the datagrid invoked with the Table menu option or the _mapdatagrid command...
Message 4 of 8
Try this from Tony, he knows more than I do about it.
http://discussion.autodesk.com/thread.jspa?threadID=604438
Murph
wrote in message news:5709166@discussion.autodesk.com...
find a guide...
Message 5 of 8
Opps Just noticed you replied there also. I just tinker with code and not
an expert with C# or anything pass lisp/VBa but I think you need to use the
FDO provider to get the data out into a usable format.
Murph
"James Murphy" wrote in message
news:5709320@discussion.autodesk.com...
Murph
find a guide...
Message 6 of 8
At last!!! I found the way to use the ImpEntity!!!
If you use AutoCAD MAP 2008 and .NET 2.0 then you have to use this file to get the examples:
sdk.dev.net.gis could be the chm or the pdf, that is located inside the AutoCad folder and Help folder...
There I got the info, the best example is:
AcMapMap currentMap = AcMapMap.GetCurrentMap();
MgFeatureService fs =
AcMapServiceFactory.GetService(MgServiceType.FeatureService)
as MgFeatureService;
MgLayerCollection layers = currentMap.GetLayers();
MgLayerBase parcelsLayer = layers.GetItem("Parcels");
string fcName = parcelsLayer.GetFeatureClassName();
MgSelectionBase selection = currentMap.GetFeatureSelection();
string selectionFilter = selection.GenerateFilter(parcelsLayer,
fcName );
MgFeatureQueryOptions queryOpts = new MgFeatureQueryOptions();
queryOpts.SetFilter(selectionFilter);
MgFeatureReader featureReader;
MgResourceIdentifier fsId = new
MgResourceIdentifier(parcelsLayer.GetFeatureSourceId());
featureReader = fs.SelectFeatures(fsId, fcName, queryOpts);
With that you get the selected feature, and with a featureReader.ReadNext(); and a featureReader.GetString(#); you get the value from the property # (number of the property), you can explore the MgFeatureReader class to get more info...
Message 7 of 8
andy62
Hi FcoLomas
can you help me?
I don't find a GetFeatureSelection method of AcMapMap
is the code below correct?
andrea
Message 8 of 8
Same issue MgSelectionBase selection = currentMap.GetFeatureSelection(); is not valid. Any luck with this? I assume the API changed yet again and the docuentation is not up to par.
