VB6 Error
VB6 Error
VB6 Error
Hi all,
I was trying to query map through VB6 application I am creating. My code is as follows:
Set amap = Application.GetInterfaceObject("Autocadmap.application.2")
Set prj = amap.Projects(0)
'Get Current Query
Set qry = prj.CurrQuery
qry.Clear
'_________________Done this far
'Attach DWG
Set atdr = prj.DrawingSet.Add("MAPTUT:\TUTORIAL IX\citymap7.dwg")
acdoc.SendCommand ("MAPWSACTION" & vbCr & vbCr & vbCr)
'Get Main Branch
Set mainqrybr = qry.QueryBranch
'Create Layout of Leaves and Branch
Set qrylf = mainqrybr.Add(kLocationCondition, kOperatorAnd)
--> the moment it reaches qrylf my VB6 gives error end quits...can somebody help urgently?
Regards
RM
Did you ever find an answer? If not, do you have "MAPTUT" defined as an
ALIAS? The file name parameter in prj.drawingset.add is supposed to be
ALIAS:drawing name.
wrote in message news:6212874@discussion.autodesk.com...
Hi all,
as follows:
'Get Current Query
qry.Clear
'Attach DWG
'Get Main Branch
help urgently?
Regards
RM
