Trying to select property and filter based layer groups together
I am using the following sub to select layers:
(defun AT:LayerFilterList (/ #Filters #List)
(or *Acad* (setq *Acad* (vlax-get-acad-object)))
(or *AcadDoc*
(setq *AcadDoc* (vla-get-activedocument *Acad*))
) ;_ or
(foreach x (entget
(setq #Filters
(vlax-vla-object->ename
(vla-item
(vla-getextensiondictionary
(vla-get-layers
*AcadDoc*
) ;_ vla-get-layers
) ;_ vla-getextensiondictionary
"ACAD_LAYERFILTERS"
) ;_ vla-item
) ;_ vlax-vla-object->ename
) ;_ setq
) ;_ entget
(if (eq 3 (car x))
(setq #List
(cons (cons (cdr x)
(cdr (nth 10 (dictsearch #Filters (cdr x))))
) ;_ cons
#List
) ;_ cons
) ;_ setq
) ;_ if
) ;_ foreach
#List
) ;_ defun
When I run this, it does not pick up layer groups created manually, only layer groups created using filters.
Can someone shed some light on this?
