tpm_elemadj
tpm_elemadj
tpm_elemadj
Hi All,
I am working on learning the topology functions and I can not get the tpm_elemadj function to work. I am using global variables for topo_id and cent_id and these print out correctly from the princ statements. but the lst and final princ statements print nil. The code follows:
;A fair amount of this code came from Rackesh at www.4d-technologies.com
;David Van Eman
(defun C:rect (/ cent_id lst TopoName topo_id)
(setq TopoName (getstring "Enter Topology name."))
(setq
Exists nil
lst '()
(if (setq Exists (tpm_acexist TopoName T nil))
(setq LoadedNow (tpm_acload TopoName))
(if Exists
(progn
(setq topo_id (tpm_acopen TopoName nil))
(Centid)
(princ (strcat "\nrect cent_id: " (rtos cent_id 2 0) "\n"))
(Adj)
(princ "\nPast Adj function")
(tpm_acclose topo_Id)
(if LoadedNow
(tpm_acunload TopoName)
(princ)
(defun Centid (/ cell ss cnt pt)
(if topo_id
(progn
(setq cell (getstring "Enter Cell number: "))
(setq ss (ssget "x" (list '(0 . "TEXT") (cons 1 cell))))
(setq cnt 0)
(if ss
(repeat (sslength ss)
(setq pt (cdr (assoc 10 (entget (ssname ss cnt)))))
(setq cent_id (tpm_elemfind topo_id 3 pt))
(princ (strcat "\nCentid cent_id: " (rtos cent_id 2 0) "\n"))
(setq ss nil)
(princ)
(defun Adj (/ final)
(princ "\n\nIn Adj")
(princ (strcat "\nTopo ID: " (rtos topo_id 2 0)))
(princ (strcat "\nCentroid ID: " (rtos cent_id 2 0)))
(setq lst (tpm_elemadj topo_id cent_id 1)) ;HERE IS THE PROBLEM
(setq final (vl-prin1-to-string lst))
(princ lst)
(princ final)
(princ "\nAdj done\n")
Thanks to anyone who takes a look at this.
Dave
FYI
System: Dell precision 490
4GB ram
Intel Xeon 5150 2.66GHz
Nvidia Quadro FX 3500
Dual Dell 2007 WFP monitors
Autodesk 2004 products
What happens if you change this line
to this
(setq topo_id (tpm_acopen TopoName T))
Are you using the VLisp editor to write and test run the code? If so add a
watch to the variables topo_id & cent_id, make sure they are REALs not
strings or integers.
Last you do have a dwg open with a topologies open when you are running it
correct?
Murph
The world is not FLAT so why is your GIS data?
http://map3d.wordpress.com
wrote in message news:5665136@discussion.autodesk.com...
Hi All,
;David Van Eman
(setq
Exists nil
lst '()
(if Exists
(progn
(Centid)
(Adj)
(if LoadedNow
(princ)
(if topo_id
(progn
(setq cnt 0)
(if ss
(setq ss nil)
(princ)
(princ lst)
(princ final)
Dave
Murph!
Thats it! Thank You!!
Dave
YW.
Murph
wrote in message news:5666730@discussion.autodesk.com...
Murph!
Dave
Murph,
FYI. It was the T in the setq topo_id line that did the trick.
Dave
That's what I thought, the T allow you to write to it, nil was read only.
Murph
wrote in message news:5666748@discussion.autodesk.com...
Murph,
Dave
