Scale of .sid Image
01:46 PM
I am importing an aerial image .sid file using Data Connect "Add Raster Image..." When I connect it and edit the coordinate system I select UTM83-17 which is the system identified in the text file. Once I attach the image, it is geographically correct but doesnt seem to be the correct scale. Everything is measuring about 1/3 of what it should, so in meters vs. feet. I want to work in feet. I have brought in some other screenshot images and scaled them and are ultimately 3x larger than the same areas of the .sid file.
