Right click menu syntax
I've got a VB Function that takes an Autocad entity as an argument. Is
there anyway to pass a selected (gripped) object to that function out
of a right-click menu?
Can try this and see if this is close to your requirement?
Private Sub AcadDocument_BeginShortcutMenuEdit(ShortcutMenu As
IAcadPopupMenu, SelectionSet As IAcadSelectionSet)
If ShortcutMenu.Item(0).Label <> "Test" Then
ShortcutMenu.AddMenuItem 0, "Test", Chr(3) & Chr(3) & "(vl-load-com)" &
Chr(32) & "(vla-runmacro (vlax-get-acad-object) ""ftest"")" & Chr(32)
End Sub
Sub fTest()
MsgBox ThisDrawing.PickfirstSelectionSet.Item(0).Handle
End Sub
Cheers,
Murali
"Bill" wrote in message
news:erpgttgas82b67indjn3nae46cfc0ls8ml@4ax.com...
> Thanks
Worked like a charm. Thanks for the second time.
Bill
>End If
>End Sub
>Sub fTest()
>End Sub
>Cheers,
>Murali
>> Thanks
