Problem with Save back iusing .NET
I have tried to save back using the method described in the .NET help files.
1. call AttachedDrawing.Lock(false) to lock the dwg file.
2. call AttachedDrawing.CloneBack
3. call AttachedDrawing.Save to commit the canges
4. Call AttachedDrawing.Unlock to unlock the dwg file.
The CloneBack call causes a MapException
The attached dwg's are not updated.
Using the ADESAVEOBJS command works fine and saves any changes to objects back to the dwgs.
Any thought? am I missing some call or setting prior to calling the cloneback method?
Any suggestions would be of help.
Paul
Autodesk has admitted at the CloneBackArea method has a problem and said to use the CloneBack method instead.
The correct sequence for saving back to the attached drawings is slightly different than what was shown above.
for each drawing in the drawing set...
1. use the method "GetNumInSaveSet" to determine if there are entities that are in the saveset and in the drawing. If there are then:
2. call AttachedDrawing.Lock(false) to lock the dwg file.
3. call AttachedDrawing.CloneBack
4. call AttachedDrawing.Save to commit the changes
5. Call AttachedDrawing.Unlock to unlock the dwg file.
Autodesk is currently researching a "work-around" for the clonebackarea method.
gluckett
Hi, I was not sure about that last step:
because the AttachedDrawing only has:
AttachedDrawing.UnlockForWrite()
and
AttachedDrawing.UnlockForRead()
is this correct?
gordon
