Message 1 of 1
OD Column Definition DefaultValue()
03:03 AM
I've been trying to read OD definitions and displaying it's contents (C++, Map SDK 2012). So far it works just fine, however getting default values of a column has proven to be a pain. Apparently, if column value isn't actully set, DefaultValue() returns the value of a previous column:
Column0: 'SomeValue'
Column1: ''
Calling DefaultValue() returns SomeValue in both cases, when it obviously shoudn't. Also, IsValid() returns true in both cases and the standard _adeattachdata command displays fields correctly. I'm guessing it's an API bug, as there's not a whole lot of room for mistakes here, but anything's possible.
Relevant code:
AcMapODTable * table;
// fetch the table pointer
AcMapODTableDefinition t_def(table->Definition());
for(int i = 0; i < t_def.Count(); ++i)
AcMapODColumnDefinition c_def;
t_def.GetColumn(c_def, i);
if(!c_def.IsValid())
acutPrintf(_T("ERROR: invalid column definition.\n"));
continue;
AcMapValue val(c_def.DefaultValue());
switch(val.Type())
case AcMap::kCharacter:
acutPrintf(_T("%s\n"), static_cast<const ACHAR *>(val));
break;
case AcMap::kInteger:
acutPrintf(_T("%i\n"), static_cast<int>(val));
break;
case AcMap::kPoint:
AcGePoint3d & p(static_cast<AcGePoint3d>(val));
acutPrintf(_T("%lf,%lf,%lf\n"), p.x, p.y, p.z);
break;
case AcMap::kReal:
acutPrintf(_T("%lf\n"), static_cast<double>(val));
break;
default:
acutPrintf(_T("ERROR: unknown type.\n"));
break;
