Method 'AttachTo' of object 'ODRecord' failed
Message 1 of 11
Programming in AutoCAD 2000, I attempted to insert a calculated value to the
current entity/object in the [slope] field of a "SEWER" table but the
following error message popped up: Run-time error '-2147352567(80020009)':
Method 'AttachTo' of object 'ODRecord' failed. A sample portion of the code
is as follows:
...Dim Tables As ODTables
Dim Table As ODTable
Dim Orecords As ODRecords
Dim Orecord As ODRecord
Dim ent As AcadEntity
Dim ObjectID As Long
Dim z As Double, z_fr As Double, z_to As Double
Dim Lngth As Double
Dim SlpFt As Variant...
...Set Tables = amobj.ODTables
Set Orecords = Tables.GetODRecords...
...For Each ent in ThisDrawing.ModelSpace...
..Lngth = ent.Length...
Orecords.Init ent, False, False
If Orecords.IsDone Then
msg = ""
Else
Set Orecord = Orecords.Record
Set Table = amobj.ODTables.Item(Orecord.tableName)
z_fr = Orecord.Item(7).Value
z_to = Orecord.Item(8).Value
z = z_fr - z_to
SlpFt = z / Lngth
Orecord.Item(19).Value = SlpFt
Orecord.AttachTo (ent.ObjectID)...
The correct calculated value for SlpFt and correct value for ent.ObjectID
are present/can be displayed when the program is interrupted due to the
above error message. Can anyone give me some insight as to what I am doing
wrong to input the SlpFt value into the record for item 'Slope' in the table
or why there is an error associated with this method? Thanks!!
Replies (10)
Message 2 of 11
I think your code is assuming that there is already a table attached to the
object. If so, then where you have 'Orecord.AttachTo(ent.ObjectID)' try
'Orecords.Update Orecord' but this requires that you change 'Orecords.Init
ent, False, False' to 'Orecords.Init ent, True, False' in order enable
updating of the table records.
Eric Smallwood
"Gregg Greer" wrote in message
news:6022F0D515D18429CCBF8D483ABD56E9@in.WebX.maYIadrTaRb...
the
code
> is as follows:
> Dim Lngth As Double
> msg = ""
> Else
> End If
> z = z_fr - z_to
> SlpFt = z / Lngth
doing
table
Message 3 of 11
Thanks for your help Eric. Yes, a "SEWER" table is already attached to
the object. I have revised the code as instructed and had to add an
additional 'Orecords.Init ent, True, False' within the select case "C-SW"
structure since setting the first Orecords.Init ent, to true and false
caused the error message 'Run-time error '-2145386417(8020004f)': Object was
open for write' and the program stopped at the 'p1 = ent.StartPoint' line.
Inserting the line of code 'Orecords.Update Orecord' in place of the
original coding causes the same run-time error as before (Method 'Update' of
object 'ODRecords' failed) only with the Update method replacing the
AttachTo method. Also, utilizing the line of code 'Orecords.Update Orecord'
causes some funky things to occur with the values z1, z2 assigned as 0
instead of the correct assigned elevation values as present in the record
for these items. So, changing the last line to 'Orecords.Update
Orecord.Item(19).Value' to try and force the SlpFt value (not an object, I
know) into this record and table now results in the error message 'Run-time
error '424': Object required', but at least the correct assigned/passed and
calculated values for z1, z2, z, and SlpFt have returned to what they should
be. Are there any other suggestions/methods to try in order to assign the
SlpFt calculated value into each empty record per field item 19 (SLOPE)?? Is
this task really this difficult or is it just me?! All help/suggestions is
greatly appreciated!!!
Below is the revised code:
Dim p1 As Variant, p2 As Variant
Dim Lngth As Double
Set Table = amobj.ODTables.Item("SEWER")
Set Orecords = Table.GetODRecords
Select Case ent.EntityType...
entLayer = ent.Layer
msg = ""
Else
Select Case entLayer
Case "C-SW" 'Layer name for sewer pipe entities
p1 = ent.StartPoint
p2 = ent.EndPoint
Orecords.Init ent, True, False...
z_to = Orecord.Item(8).Value...
z = z_fr - z_to
SlpFt = z / Lngth
Orecords.Update Orecord.Item(19).Value...
"Eric Smallwood" wrote in message
news:AC8E81DBBFD9FF94A0BCFBE2E10D100E@in.WebX.maYIadrTaRb...
the
> Eric Smallwood
> the
> code
> > is as follows:
> > Dim Lngth As Double
> > msg = ""
> > Else
> > End If
> > z = z_fr - z_to
> > SlpFt = z / Lngth
ent.ObjectID
> doing
> table
Message 4 of 11
I think the problem may be that one or more of your sewer lines doesn't have
an object data table. I extracted a section of code I have for updating an
object data table, modified it a little to do what I think you're looking
for, and then I tested it out on a set of lines with an object data table I
called "SewerTable." The test routine worked fine, it extracts two numbers
from the table, subtracts them and then divides by the length of the line,
and then puts the number into the table. However, when I detached a table
from one of the lines and ran the routine again, then I received an error
message. It was trying to read a record from an absent table.
So you might check to see if all your lines have tables, or put a condition
in the routine to pass over lines without tables. I attached the test
routine I was working on.
Eric Smallwood
Message 5 of 11
Now that I take another look at your code, I think the problem is that the
'If Orecords.IsDone Then' check doesn't bypass the remaining code, meaning
that if an object doesn't have a table, it's stil going to head for the code
that is looking to update the table, and that's where the error message
occurs. So, I think you need to move the 'End if' to the bottom of the code
but before the Next.
Eric Smallwood
news:322DC5D5B0B5846310CB06BD764E2BDF@in.WebX.maYIadrTaRb...
was
of
Orecord'
'Run-time
and
should
Is
> Dim Lngth As Double
> msg = ""
> Else
> End If
> p1 = ent.StartPoint
> p2 = ent.EndPoint
> z = z_fr - z_to
> SlpFt = z / Lngth
Message 6 of 11
Thanks again for your assistance with this Eric. However, I am now
completely stumped as to why it is not 'updating' the records for each
iteration. It should work now as I have made changes as suggested as well
as some others, but it still does not update each record that it should for
items SLOPE and ZLENGTH. The record for each of these fields remain
unchanged (default value '0.0000' respectively) when the routine finishes
and the object data records for these items for each pipe entity is checked.
There are no error messages when the program finishes. It bypasses line
entities that do not include an attached object data table and also checks
to see if a "SEWER" table exists. For purposes of checking whether the
values for each record within the invert elevations are recognized/passed
and correct calculations for the slope and 3D pipe length are assigned, I
included code to pass the extracted elevation values and calculated values
to an Excel spreadsheet for each record iteration and it works great. Any
other ideas/suggestions to make this code work for updating the records
within the object data table is appreciated . Below is the latest version
of code:
Private Sub ComGetEnt_Click()
Dim x As Double, y As Double
Dim z_from As Double, z_to As Double
Dim Zlngth
Dim Lngth
Dim rise
Dim SlpFt
Dim acadApp As AcadApplication
Dim amobj As AcadMap
Dim acadObject As Object
Dim objectID As Long
Dim proj As Project
Dim DrawSet As DrawingSet
Dim AttachedDwg As AttachedDrawing
Dim Fields As ODFieldDefs
Dim Field As ODFieldDef
Dim entHandle As String
Dim entType As String
Dim entLayer As String
Dim dwgName As String
Dim Fieldval As ODFieldValue
Dim msg As String
Dim pv_temp As String
Dim pb_quit As Boolean
Dim Excel As Object
Dim excelSheet As Object
Dim RowNum As Integer
Set acadApp = ThisDrawing.Application
Set amobj = acadApp.GetInterfaceObject("AutoCADMap.Application")
Set proj = amobj.Projects(ThisDrawing)
dwgName = ThisDrawing.Name
Me.Hide
''Starts/Loads Excel
On Error Resume Next
Set Excel = GetObject(, "Excel.Application")
If Err <> 0 Then
Err.Clear
Set Excel = CreateObject("Excel.Application")
If Err <> 0 Then
MsgBox "Could not load Excel.", vbExclamation
End
On Error GoTo 0
Excel.Visible = True
Excel.Workbooks.Add
Excel.Sheets("Sheet1").Select
Excel.ActiveWorkbook.SaveAs (dwgName)
Set excelSheet = Excel.ActiveWorkbook.Sheets("Sheet1")
RowNum = 1
excelSheet.Cells(RowNum, 1).Value = "Mapkey"
excelSheet.Cells(RowNum, 2).Value = "3DLength"
excelSheet.Cells(RowNum, 3).Value = "Slope_FT"
excelSheet.Cells(RowNum, 4).Value = "Rise_FT"
excelSheet.Cells(RowNum, 5).Value = "2DLength"
excelSheet.Range("A1:E1").Font.Bold = True
Set Table = proj.ODTables.Item("SEWER")
If Table Is Nothing Then
MsgBox "Object Data Table does not exist"
Exit Sub
For Each ent In ThisDrawing.ModelSpace
Case acLine
entHandle = ent.Handle
Lngth = ent.Length
p1 = ent.StartPoint
p2 = ent.EndPoint
If Orecords Is Nothing Then
MsgBox "No Object Data associated"
Exit Sub
Case "C-SW"
If (Orecords.IsDone = False) Then
Set Orecord = Orecords.record
pcounter = pcounter + 1
z1 = Orecord.Item(6).Value
z2 = Orecord.Item(7).Value
x = p1(0) - p2(0)
y = p1(1) - p2(1)
'Calculate the 'rise' value
z = z1 - z2
'Calculate the 3D Line length
Zlngth = Sqr((Sqr((x ^ 2) + (y ^ 2)) ^ 2) + (z ^ 2))
'Calculate the slope in ft/ft
SlpFt = z / Lngth
Orecord.Item(2).Value = Zlngth
''This portion of routine places extracted data into Excel worksheet
RowNum = RowNum + 1
excelSheet.Cells(RowNum, 1).Value = entHandle
excelSheet.Cells(RowNum, 2).Value = Zlngth
excelSheet.Cells(RowNum, 2).NumberFormat = "0.000000"
excelSheet.Cells(RowNum, 3).Value = SlpFt
excelSheet.Cells(RowNum, 3).NumberFormat = "0.000000"
excelSheet.Cells(RowNum, 4).Value = z
excelSheet.Cells(RowNum, 4).NumberFormat = "0.000000"
excelSheet.Cells(RowNum, 5).Value = Lngth
excelSheet.Cells(RowNum, 5).NumberFormat = "0.000000"
End Select
Set Orecords = Nothing
End Select
Next
excelSheet.columns("A:G").AutoFit
If pcounter > 0 Then
MsgBox ("Found " & pcounter & " Sewer pipe entities.") '(...Data Transfer
Complete.")
End Sub
news:FE3B7F1E5132C379B7BD9DDF22BDE77B@in.WebX.maYIadrTaRb...
code
code
> Eric Smallwood
"C-SW"
> was
line.
'Update'
> of
> Orecord'
record
I
> 'Run-time
> and
> should
the
(SLOPE)??
> Is
is
> > Dim Lngth As Double
> > msg = ""
> > Else
> > End If
> > p1 = ent.StartPoint
> > p2 = ent.EndPoint
> > z = z_fr - z_to
> > SlpFt = z / Lngth
Message 7 of 11
you'll get it 😉 First, check a little thing. With this latest code, I
noticed that there are a few minor errors that you probably have fixed. 'z'
'z1' & 'z2' aren't declared. But apart from this, I broke out the essential
section of the code (minus the Excel connect) and ran it using a test
drawing, and what I found was that when I created an object data table with
'integer' fields, the slope wasn't seen because the slope is a real not an
integer. So, check your object data table to see whether field 19 (or 18) is
an integer or a real. The code worked fine when I made this change.
Eric Smallwood
Message 8 of 11
Thanks Eric. Yes, the variables 'z1', 'z2', and 'z' are declared in the
program. I am about to go ballistic with this! The SLOPE & ZLENGTH fields
in the SEWER object data table are and always have been defined as 'real'
number fields. So you would think that declaring 'Zlngth As Double', and
'SlpFt As Double', etc., would work and the records within the fields woul
be updated with the assigned values per iteration. No such luck! The
program continues to defy every attempt to find a way to populate/update the
records. This has tested my patience to say the least! But I'm going to
keep at this code until it works properly even if it drives me over the edge
in the process. Any other suggestions would be most helpful because right
now I'm at a loss for other ideas.
news:B85B804CEA5418BBA6AF8D95B0A34AD0@in.WebX.maYIadrTaRb...
'z'
essential
with
is
> Eric Smallwood
Message 9 of 11
news:7C3256D897B1173A4323345AC83D4D07@in.WebX.maYIadrTaRb...
> ... The program continues to defy every attempt to find a way to
populate/update
> the records. This has tested my patience to say the least! But I'm going
to
edge
Hello Gregg,
Okay, here's the issue. The Map 4 api
has a bug that prevents updating an
existing object data record on entities.
The workaround is to update the record
in memory, re-assign it to the entity
as a new record, and then delete the
original record.
In this example, I've already obtained
the iNth record oRec from the records
collection oRecs in the odtable oTbl on
a specific acad entity oEnt:
'' first, release the collection iterator
Set oRecs = Nothing
'' next update the odvalue in memory
oRec.Item(0).Value = "new value"
'' now attach the updated record to the entity
If oRec.AttachTo(oEnt.ObjectID) Then
'' if the new record was added, delete the old
'' get the record collection
Set oRecs = oTbl.GetODRecords
If oRecs.Init(oEnt, True, False) Then
'' move to the correct record number
For i = 0 to iNth
oRecs.Next
Next
'' finally, delete the old record
If Not oRecs.Remove Then
'' couldn't delete old record
Else
'' couldn't get iterator
Else
'' couldn't attach new record
This code will work for both Map 4 and
all later versions (where the defect has
been fixed), and is only slightly more
work than a direct update.
Sorry for the hassle.
rdh.
Message 10 of 11
argh 😉
Okay, now, I took the code, created a test drawing, created some lines and
placed them on layer "C-SW", created an object data table called "Sewer"
with 20 fields (0-19), attached the table to the lines, put in some values
in for fields 6 and 7, and then ran the code from the Tools, Macro menu, and
the thing worked. The Excel file popped up and the fields were populated,
field 2 had the length and field 19 had the slope.
So, here is an exact copy of what I tried:
Option Explicit
Dim z1 As Double, z2 As Double, z As Double
Dim Zlngth As Double, Lngth As Double, SlpFt As Double
Dim proj As Project
Dim Excel As Object
Exit Sub
'Starts/Loads Excel
If Err.Number <> 0 Then
Err.Clear
Exit Sub
Excel.Workbooks.Add
'dwgName = ThisDrawing.Name
'Excel.ActiveWorkbook.SaveAs (dwgName)
RowNum = 1
On Error GoTo Err_Control
Case acLine
entLayer = UCase(entLayer)
Lngth = ent.Length
p1 = ent.StartPoint
p2 = ent.EndPoint
Exit Sub
Case "C-SW"
x = p1(0) - p2(0)
y = p1(1) - p2(1)
z = z1 - z2
SlpFt = z / Lngth
worksheet
RowNum = RowNum + 1
End Select
End Select
Next
Set Excel = Nothing
Exit Sub
Err_Control:
MsgBox Err.Description
End Sub
Message 11 of 11
ahhh. I was working from 4.5 and didn't encounter the bug. Well done
(hopefully ;)).
Eric Smallwood
"Richard D. Howard [Autodesk GIS]" wrote in
message news:22C58010C4D3214FB281FFB17A3AFAFC@in.WebX.maYIadrTaRb...
> populate/update
going
> to
> edge
right
> Hello Gregg,
