MDB data to Object Data
Message 1 of 9
Hi all,
Do any one know how to get MDB data as object data on the basis of a link, with the fields available in the object data table?
Please let me know of any such possibilities.
MNRaghu
Replies (8)
Message 2 of 9
We use OD to hold an ID that is used to retrieve data from an Access database. Is that what you are looking for? Or do you want to assign object data to an object automatically by connecting it to a database so the object data changes with the database changes?
Bart
Message 3 of 9
Bart,
Yes.This is my requirement.
Alternatively, is it possible that I have blank object data fields and fields by similar name in an MDB table.
Using a link, can I tranfer the values from MDB to Object data table?
Is this possible?
Thanks You,
MNRaghu
Message 4 of 9
I would think it very possible. It would require a degree of automation though. I use VBA code and the ADO connection object to connect my Maps to an Access database. I know that you can create a Link Template in MAP, but I don't know how that works, however there any number of people in the group who could help you with that.
I would think that you would need to assign a unique Key to each object that would be a record id in the database. Then you would need to write a routine that was either fired mannually by the user, called on startup or fired using a VB timer control, to connect to the Database and check for updates. I don't think that there is a way to link the drawing objects so that changes in the database happen as the affect the drawing objects instantly.
If you would like help with the ADO connection to the Database please let me know and I will be happy to share the code we use.
EDIT: To answer the other question, yes OD fields can be blank, and the fields in the database can be blank so long as the are not "required".
Bart Message was edited by: bart1123
Message 5 of 9
Hi Bart,
Thanks for your views.
I request you share the code the performs ADO connection to the Database which would help me to move a step ahead on this issue.
MNRaghu
Message 6 of 9
MNRaghu,
Below is the code that I use to open and close the ADO object to connect to the database. Following that is the code that prompts the user for a selection on screen, checks for Object Data and reads the OD if found. While this does not show how to write data from the database to the OD I hope that it is enough to give you a good primer on where to look. By the way this function was written entirely from the help files in Map on ActiveX autoation and API help.
I hope this helps you.
Bart
***************************BEGIN CODE***********************
' Module : modDataBase
' DateTime : 6/3/2005 10:29
' Author : bart
' Purpose :This holds the Database connection string and deals with opening and _
closing the connection
Option Explicit
Dim sConn As String
Public oConn As ADODB.Connection
'Make sure you have a reference in the project to MS Active Data Objects 2.x (I use 2.8)
Public Sub OpenDB
Set oConn = New ADODB.Connection
sConn = "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=C:\MyData\Database.mdb;" & _
"Persist Security Info=False"
oConn.Open sConn
Exit Sub
CheckError:
MsgBox "Database Connection Error" & vbCrLf & Err.Number & " - " & Err.Description
'LocErr = True
Exit Sub
Resume Next
End Sub
Public Sub CloseDB()
If oConn.State = 1 Then
oConn.Close
Set oConn = Nothing
End Sub
The following code prompts the user to select an object with Object Data Attached, reads the value of the object data and querries the database for records matching the value of the Object Data
Public NEW_TLNUM As String
Public rsCable As ADODB.Recordset
Public Sub GetCableID()
Dim ODrcs As ODRecords
Dim boolVal As Boolean
Dim returnObj As AcadObject
Dim basePnt As Variant
Dim i As Integer
Dim answer As Variant
On Error GoTo errorhandler
'**********************************NEW****************
Dim amap As Object
Dim ODfdfs As ODFieldDefs
Dim ODfdf As ODFieldDef
Dim ODtb As ODTable
Dim ODrc As ODRecord
Set amap = ThisDrawing.Application. _
GetInterfaceObject("AutoCADMap.Application.2")
Set ODfdfs = amap.Projects(ThisDrawing).MapUtil.NewODFieldDefs
ThisDrawing.Utility.GetEntity returnObj, basePnt, "Select an object"
If returnObj.ObjectName = "AcDbBlockReference" Then
GetNodePic returnObj.Handle
Exit Sub
' Add Column Headings and Defaults
Set ODfdf = ODfdfs.Add("CAB_ID", "Cab Disc", "23", 0)
Set ODfdf = ODfdfs.Add("Route_ID", "Rout Disc", "66", 1)
Set ODrcs = amap.Projects.Item(ThisDrawing). _
ODTables.Item("CABLE").GetODRecords
'Prompt user to select an object
boolVal = ODrcs.Init(returnObj, True, False)
For i = 0 To ODrcs.Record.Count - 1
NEW_TLNUM = ODrcs.Record.Item(i).Value
Next i
'*****************GET CABLE******************
Const conErrInvalidNull = 94
Const conErrNotObject = 438
Const conErrNoRecord = 3021
OpenDB 'open Connection
Set rsCable = New ADODB.Recordset
sSQL = "Select * from CABLE where CAB_ID = '" & NEW_TLNUM & "'" 'build SQL query to find record based on Cable ID
rsCable.Open sSQL, oConn, , adLockOptimistic 'Finds record in Database based on CAB_ID
If Not rsCable.EOF Then 'If record is found then load record into form
Load frmCable
frmCable.Show
Exit Sub
errorhandler:
Select Case Err
Case conErrNotObject
MsgBox ("This is not a cable."), vbExclamation
Case conErrInvalidNull
Resume Next
Case conErrNoRecord
Resume
Case Else
MsgBox ("Unexpected error :" & Err.Description), vbExclamation
End Select
End Sub
********************************END CODE************************
Message 7 of 9
Bart,
Thank a lot for sharing the code.
That should be more than enough for me to proceed.
Thanks again......
MNRaghu
Message 8 of 9
One way around customization is to export your data to a SHP - taking all the MDB data to SHP. Then import the SHP into a new DWG and have it create Object Data during the import.
Message 9 of 9
LochDhu,
That's a useful and good idea.
MNRaghu
