MAPSKINMAP + .NET application = kaboom
Message 1 of 13
Anyone else tried using a WinForm in a managed
extension (NETLOAD) with the new fangled MAP
skin UI ?
A MAP 2006 user is trying to run one of my apps
that displays a simple Windows form as a modal
dialog.
When they have the new style skin enabled, the
form's client area doesn't paint, and disappears
as soon as they click on it, leaving the AutoCAD
window disabled, and forcing them to kill acad.exe
through task manager.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006
http://www.acadxtabs.com
Replies (12)
Message 2 of 13
I'm not surprised. The Mapskinmap is like the 3rd headlight on a car, the
one center on the
front of the hood. Sounds like a good idea but.............
Murph
"Tony Tanzillo" wrote in message
news:5108651@discussion.autodesk.com...
skin UI ?
dialog.
Message 3 of 13
> car, the one center on the front of the hood.
No, at least that would have 'some' use. The MapSkin is USELESS
cosmetics that SLOW DOWN an otherwise useful app.
Terry
Message 4 of 13
Thanks. I've advised them to turn it off and
pretend it doesn't exist.
"James Murphy" wrote in message news:5108654@discussion.autodesk.com...
one center on the
Murph
skin UI ?
dialog.
Message 5 of 13
Tony:
Also the skin engine it's a third party development: www.stadock.com , may
be them can help you if your customer insists using this "new feature".
Gaston
news:5108951@discussion.autodesk.com...
one center on the
Murph
skin UI ?
dialog.
Message 6 of 13
Tony Tanzillo wrote:
> When they have the new style skin enabled, the form's client area
> doesn't paint, and disappears as soon as they click on it, leaving
> the AutoCAD window disabled, and forcing them to kill acad.exe
I threw together a form with a few controls in VS2005, then displayed it
with ...
Public Class MyTestProj
_
Public Sub ShowMyForm()
Dim dlg As New MainForm()
Application.ShowModalDialog(dlg)
End Sub
End Class
... and it seems to work whether the Map Skin is on or off.
If you have something you want me to test on Map2006, email me at dotson
[at] dotsoft.com.
Terry
Message 7 of 13
Of course there could be something wrong with your users machine, like
low resources (the skin probably eats it up).
Tery
Message 8 of 13
Thanks. I'm familar with the tools they're using
(the theme painting is done by a library from
StingRay software).
The problem is actually quite nasty. In addition
to the other symptoms, controls on the form
fail to respond to resizing the form.
I've attached two screenshots they made
showing the form with and without skins
(strangely, the docked palette which is in
the same DLL, seems have no problems
with the skins whatsoever).
"Gaston Nunez" wrote in message
news:5110575@discussion.autodesk.com...
Tony:
Gaston
Message 9 of 13
Hi Tony,
Month ago I made few posts to .NET Customization NG indicating that
"something goes wrong" when displaying modal form- certain properties of my
form simply got ignored by Map. Later on I discovered that switching off the
skin solves majority of problems. Anyway, if anyone's simply forced (?) to
use skinned Map try avoiding following when designing your form:
- Buttons on the Form can be only rtNormal - buttons can't be Flat
- Form's opacity setting gets ignored (only values 0 and 100 are accepted)
- Form's Border property can't be set to FixedToolWindow
- Strange bahaviour when Form's ShowInTaskbar property is set to False
Switching off the Map's skin via Registry setting:
HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R16.2\ACAD-4002:409\Applications
\AcMap
DWORD value name: SkinEnabled
Should be set to 0 to disable Map skin.
Maksim Sestic
skin UI ?
dialog.
Message 10 of 13
Hi there.
Map 2006 is not compatible with .net framework 2.0
If you have intalled only the version 1.0 or 1.1 nothing "buged" should happen.
But of course, if you have 2.0 as well, you probably don´t want to uninstal it.
So, the workaround is this:
get to acad.exe.config file
(normaly in c:\program files\autodesk map 2006)
open it with notepad (ie) and replace the text there with the following:
No matter wich version of the .net framework is installed, Map will always point to the version 1.1
Hope it helps..
cheers,
Clara
Message 11 of 13
the text didn´t apear because of the signs "< >"
So, where there is a « should be a "<" (without the quotation marks)
and, where´s a » should be a ">"
The browser actualy reads the signs....
The text is:
«configuration»
«startup»
«supportedRuntime version="v1.1.4322"/»
«/startup»
«/configuration»"
Message 12 of 13
Your solution may work from what I read someplace before, how ever a word of
caution on that method. If you install another program that need version 2.0
they have look for version 1.0 or 1,1 on your system and either uninstall it
or disable it in some way. Anything with The MS or AutoDesk stamp of
approval "should" be ok it's those other software you need to watch for.
Murph
wrote in message news:5161712@discussion.autodesk.com...
Hi there.
happen.
it.
Hope it helps..
cheers,
Clara
Message 13 of 13
wrote
>> Hi there.
Hi. sorry to say this, but you're mistaken.
There is no framework 2.0 installed on the problem
system(s), and that has absolutely nothing to do
with it.
The application uses framework 1.1, and the
acad.exe.config file is set to use that version as
well.
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006/2007
