Link Template and VB.Net
I'm trying to create a link template using VB.NEt
does anyone have sample code I could use to get started?
I check in the Map ObjectArx 2.0 but I could not find any sample.
thank you
Louis
I ran into this a few months ago. At that time I couldn't find any .NET port of the Connectivity Automation Object (CAO)...and I ended up using the COM CAO object to work with Link Templates.
Scott Friedrich
thank you!
... null
I have finally been able to create a link template using the CAO COM component.
now, I need to create a link between a table entry and an object.
I found the following command:
LT.CreateLink(ObjectID as Integer, pKeyValues as CAO.KeyValues)
where LT is a CAO.LinkTemplate obtained from the creation of the new LinkTemplate (objLinkTemplate.Add[...])
for the ObjectID parameter, can I simply use a Autodesk.Autocad.DatabaseServices.ObjectID (converted to a string)
for the pKeyValues parameter, I need to create a new keyValue, using:
keyValues.add(fieldName as string, value as Object)
what does the value parameter represent? The object I want to connect to?
I found what I was doing wrong
it was in the LT.CreateLink(ObjectID as integer, pKeyValues as CAO.KeyValues)
for the ObjectID parameter, I was doing something like this
dim id as ObjectId
'get the ObjectId of an entity
dim intId as integer
intId = Cint(id.ToString)
instead of doing:
intID = id.OldId
I was always getting a fatal error that caused AutoCad to close.
Hope this might be of some help to someone
