How to Turn Off AutoCAD Map Message
dohenry
Message 1 of 1
dohenry
Hi All
I am creating a vb.Net procedure that Attaches a Drawing, Queries information from the Drawing and then Detaches the drawing. This is all working fine.
However when the drawing is Detached, the “AutoCAD Map Messages” Dialog appears as per attached screenshot.
I have search the Forums and Googled the problem but I can only find suggest on how to resolve issues where the Dialog is not appearing.
I have tried several thinks to stop this dialog appearing including checking the following settings.
Filedia: 1
AttDia: 0
CmdDIA: 1
QAFlags: 16 and tried 0
If have also tried including the following line in my code but the Dialog is stopping it running until the user closes the Dialog.
doc.SendStringToExecute("{ENTER}", True, False, False)
I am running AutoCAD Civil 3D 2015 on a Windows 7 64bit machine.
For the application to run without the user having to close the dialog I either need a way to disable the dialog from appearing (Ideally) or a method to acknowledge it when it does open.
Any help on this matter would be greatly received.
Replies (0)
