GML export v.3
GML export v.3
GML export v.3
I have several question.
In AutoCAD MAP 2008 is a import and export to GML version 3. Is there option export in version 2?
Why there is no possibility set mode Create of Fixed?
My installation do not export to GML. No files are created. This function is failed. In Map 2007 it works properly.
Zdena
Zdena,
I have the same problem In my case it appears to be a problem with the coordinate system. I have files created when I use a lat long coordinate system, rather than the UTM.
Have been in touch with Autodesk but am not expecting a fix anytime soon.
