Find Tuning angle at a point in polyline using AutoCAD .net
Hi All,
How can we find the bending angle from polyline which is having two segments i.e three points using AutoCAD .net.
I have a polyline which is having more vertices and i want to find how much turn is taking place before and after at each point.
Any support on this calculation?.
Dayalan
Alfred.NESWADBA
hopfully that is what you are looking for, let's know if not.
That code only calculates straight angles between vertices (projected on WCS XY plane), so for any other planes or in case there are arcs included the calcualation would have "to learn" that siutations.
(minimal error handling)
Dim tDoc As Document = Application.DocumentManager.MdiActiveDocument
Dim tED As Editor = Nothing
If tDoc IsNot Nothing Then
  tED = tDoc.Editor
  Dim tTrAct As Transaction = Nothing
  Try
    Dim tRes As PromptEntityResult = tED.GetEntity("Select Object: ")
    If (tRes IsNot Nothing) AndAlso (tRes.Status = PromptStatus.OK) AndAlso (tRes.ObjectId.IsValid) Then
      tTrAct = tDoc.Database.TransactionManager.StartOpenCloseTransaction
      Dim tDbObj As DBObject = tTrAct.GetObject(tRes.ObjectId, OpenMode.ForRead)
      If (tDbObj IsNot Nothing) Then
        Dim tCurve As Curve = TryCast(tDbObj, Curve)
        If tCurve IsNot Nothing Then
          Dim tPnts As Point3dCollection = New Point3dCollection
          tCurve.GetStretchPoints(tPnts)
          If (tPnts IsNot Nothing) AndAlso (tPnts.Count >= 3) Then
            For i As Integer = 1 To tPnts.Count - 2
'get point before and after current vertex Dim tPnt1 As Point3d = tPnts(i - 1) Dim tPnt2 As Point3d = tPnts(i) Dim tPnt3 As Point3d = tPnts(i + 1)
'get 2D-projected vectors from prev. to current point as well as from current to next vertex Dim tVec1 As Vector2d = tPnt2.GetVectorTo(tPnt1).Convert2d(New Plane) Dim tVec3 As Vector2d = tPnt2.GetVectorTo(tPnt3).Convert2d(New Plane)
'now get the angle between these vectors Dim tAng As Double = tVec1.GetAngleTo(tVec3) Debug.Print("Vertex " & i.ToString & ": Angle = " & Format(tAng * 180 / Math.PI, "#.00")) Next End If End If End If Else Call MsgBox("No (valid) object selected, function cancelled.") End If Catch ex As Exception 'TODO run error handling Finally If tTrAct IsNot Nothing Then tTrAct.Dispose() : tTrAct = Nothing End Try End If
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
