DotNet Buffer & Overlay
O_Eckmann
Mentor Mentor
O_Eckmann
I would like to mimic MAPFDOBUFFERCREATE & MAPGISOVERLAY but with native CAD objects (Point, Insert, Polyline, MPolygon...) with possibly copy of OD from source to target MPolygon.
I don't want to reinvent the wheel, so I've found 2 possible ways :
 - SqlServer Spatial : https://learn.microsoft.com/en-us/dotnet/api/system.data.entity.sqlserver.sqlspatialservices.buffer?...
 - Net Topolgy Suite : https://github.com/NetTopologySuite/NetTopologySuite/wiki/GettingStarted
Has anybody some experience in one of these solution, or a better solution perhaps? I'm looking for leads before taking the plunge.
Olivier Eckmann
fieldguy
I have code that asks the user for a closed polyline and an offset distance. The polyline gets converted to MgGeometry with this:
Polyline bdy = (Polyline)tr.GetObject("pline objectid", OpenMode.ForRead, false);
MgGeometry geom = null;
geom = PolylineGeometryConvert((Polyline)bdy); // returns mgpolygon (closed)
then buffer with this:
MgGeometry buffgeom = geom.Buffer("offset", null);
then convert to pline:
Polyline newp = new Polyline();
newp = PolylineEntityConvert(buffgeom);
This reqiures a reference (using OSGeo.MapGuide) on my pc in C:\Program Files\Autodesk\AutoCAD 2025\Map\bin\GisPlatform (might need all 3 osgeo dll's)
O_Eckmann
Hi @fieldguy ,
Thanks for your answer.
Last month I need to overlay 40 000 points over 100 polygons. I export to SHP and use GisOverlay. It works, but it takes more than 2 minutes where QGIS takes only 18s with same data.
I've also used buffer from FDO lines, but sometimes it fails to create complex buffer (with hole).
I don't know if it's due to API or FDO, but I prefer to test other solution than native Map API.
Olivier Eckmann
