'Cannot be erased by caller' run-time error message - Trying to delete a block
In AutoCAD Map 2000 I am trying to check for an existing block and, if
exists, delete the block before inserting another block in Paper Space, ie.
the block "QSSwrLgnd" already exists and before I insert another block
"QSWtrLgnd", I want to delete the first block. However the program stops on
line 'ThisDrawing.Blocks.Item(i).Delete' and a run time error message
"Cannot be erased by caller" is displayed. What's up with this? I may be
way off base here with the code so be easy on me if I am (I don't do this
kind of thing oftenenough) - Thanks in advance for all help/suggestions/etc.
Dim EntGrp(0) As Integer
Dim EntPrp(0 TO 1) As Variant....
....Set ssnew2 = ThisDrawing.SelectionSets.Add("tmpblock")
EntGrp(0) = 2
EntPrp(0) = "QSSwrLgnd"
EntPrp(1) = "QSWtrLgnd"
ssnew2.Select acSelectionSetAll, EntGrp, EntPrp
If ssnew2.count >= 1 Then
For i = 0 To ssnew2.count - 1
Next i
ThisDrawing.SelectionSets.Item("tmpblock").Delete....
Gregg,
Here is the problem & resolution from the API Help:
When you delete an object in a collection, all remaining items in the
collection are reassigned a new index based on the current count. You should
therefore avoid loops that delete an object while iterating through the
collection. For example, the following VBA code will result in a runtime
error:
For i = 0 To ThisDrawing.Groups.Count - 1
ThisDrawing.Groups.Item(i).Delete
Next I
Instead, use the following VBA code to delete all members in a collection:
for each obj in ThisDrawing.Groups
obj.Delete
next obj
Scott
"Gregg Greer" wrote in message
news:1B08F56E6E9729C530CF45BA45131CF9@in.WebX.maYIadrTaRb...
ie.
on
> EntGrp(0) = 2
> Next i
> End If
Thanks for the info. Scott. I have revised my code as recommended and also
made some other changes but I now get the "run-time error '9': Subscript out
of range" message on line 'ssnew2.Select mode, Pt3, Pt4, EntGrp2, EntPrp2'.
I am completely stumped as to why this is happening as I have declared an
array with the correct number of elements for each point (Pt3 & Pt4) as well
as group code and name of blocks to filter. Again, all help/suggestions is
greatly appreciated.
Dim EntPrp(0 To 1) As Variant
Dim Pt3(0 To 2) As Double
Dim Pt4(0 To 2) As Double
Dim blockRefObj As AcadBlockReference
Dim ssnew2 As AcadSelectionSet....
'create a selection set in PaperSpace
'Filter for Group code 2, the block name
EntGrp(0) = 2
'The name of the blocks to filter for
mode = acSelectionSetWindow
Pt3(0) = -0.25: Pt3(1) = -0.25: Pt3(2) = 0
Pt4(0) = 4: Pt4(1) = 12.5: Pt4(2) = 0
ssnew2.Clear
'find the block
ssnew2.Select mode, Pt3, Pt4, EntGrp, EntPrp
For Each blockRefObj In ssnew2
blockRefObj.Delete
Next
insertionPnt(0) = -0.25: insertionPnt(1) = 1#: insertionPnt(2) = 0
Set blockRefObj = ThisDrawing.PaperSpace.InsertBlock(insertionPnt,
"QSSwrLgnd", 2#, 2#, 2#, 0)....
"Scott Friedrich" wrote in message
news:0490F54D902FB269764CB1B22A1CF25D@in.WebX.maYIadrTaRb...
> Gregg,
should
> error:
> Next I
> obj.Delete
> next obj
> Scott
> ie.
> on
be
this
> > EntGrp(0) = 2
> > Next i
> > End If
You have a mistake defining the Group Code Value, it should be this:
Dim EntPrp(0) As Variant
EntPrp(0) = "QSSwrLgnd,QSWtrLgnd"
Scott
news:C46E69F9109ECADA307414926908A90B@in.WebX.maYIadrTaRb...
also
out
EntPrp2'.
well
is
> EntGrp(0) = 2
> ssnew2.Clear
> 'find the block
> blockRefObj.Delete
> Next
> End If
> > Gregg,
> should
> > error:
> > Next I
collection:
> > obj.Delete
> > next obj
> > Scott
Space,
> > ie.
stops
> > on
may
> be
> this
> > > EntGrp(0) = 2
> > > Next i
> > > End If
