Automate Topology creation
I want a way to do a series of command
Map--> Topology --> Create.
Map--> Object Data, detach from objet
Map --> Database --> generate links
Map--> Query--> topology thematic query.
This series of command that can take a few dozens of clicks, and I sometimes
have to repeat it a few times on several drawings, beeing able to program it
would greatly help me, I'm quite familiar with VBA and VB, but I can't find
good help on the map object.
Can someone here help me on this one.
Thanks.
Many of the AutoCAD commands can be typed with a starting "-" which calls
the command from the keyboard without a dialog box. From there you can
experiment to sort out the keyboard responses you need and feed all that
into a menu command (or a script file, which would probably be best as you
will be combing several commands sequentially)
After you get one command to work as you need simply sort out he process for
a second command, then you can append the two commands onto one menu item or
into the script file.
The first command you need "_MAPCREATE" didn't respond to "-MAPCREATE",
however after I set the FILEDIA and CMDDIA variables to 0 it worked without
the dialog box. See Text screen extract below. As you can see some of the
script data would need to be varied if you expect more than one topology to
be created.
Laurie Comerford
CADApps
www.cadapps.com.au
Command: _MAPCREATE
Command: -mapcreate
Unknown command "-MAPCREATE". Press F1 for help.
Command: filedia
Enter new value for FILEDIA <1>: 0
Command: cmddia
Enter new value for CMDDIA <1>: 0
Command: _mapcreate
Enter topology name: Fred
Enter topology description: It's a nice day to experiment
Enter topology type (Node/neTwork/Polygon)
: P
Filter selected node objects? (Yes/No) : N
Automatically select node objects? (Yes/No) : Y
Create new nodes? (Yes/No) : Y
Enter target layer for new nodes (? for list) <0>: Fred
Enter block for creating new nodes (? for list) :
Filter selected links? (Yes/No) :
Automatically select links? (Yes/No) :
Filter selected centroids? (Yes/No) :
Automatically select centroids? (Yes/No) :
Enter target layer for new centroids (? for list) <0>: FRED)
Enter block for creating new centroids (? for list) :
Automatically create missing centroids? :
Allow multiple centroids? (Yes/No) :
Allow incomplete areas? (Yes/No) :
Highlight Errors? (Yes/No) :
Mark Errors? (Yes/No) :
Creating Polygon topology: Fred....
Writing topology information to the drawing...
Topology successfully created.
"Yves Allaire" wrote in message
news:096107FDB4784F50874A69214881B0CD@in.WebX.maYIadrTaRb...
sometimes
it
find
> Thanks.
Thanks, but instead of using script, is there a way to call a command within
VBA, like we used to do with LISP.
Thanks.
"Laurie Comerford" a écrit dans le message de news:
DDB43F49BBBA7EDDBC9E9B9C680819E5@in.WebX.maYIadrTaRb...
> Hi,
for
or
without
the
to
> be created.
> Laurie Comerford
> CADApps
> www.cadapps.com.au
> Command: _MAPCREATE
> Command: -mapcreate
> Command: filedia
> Command: cmddia
> Command: _mapcreate
: P
> sometimes
program
> it
> find
> > Thanks.
Sorry, I found it... the Sendcommand method will do the work!
> Hi,
for
or
without
the
to
> be created.
> Laurie Comerford
> CADApps
> www.cadapps.com.au
> Command: _MAPCREATE
> Command: -mapcreate
> Command: filedia
> Command: cmddia
> Command: _mapcreate
: P
> sometimes
program
> it
> find
> > Thanks.
Hi Yves,
All of the information I provided before is still needed.
In the SendCommand process you still need to effectively create the Script
file (but as a string variable).
The only thing that you can do differently is use some preceding input in
the VBA to effectively write the script file to have different variables
such as the topo name.
You may even find it easiest in this case to use VBA to write the script
file and then run it.
Laurie Comerford
CADApps
www.cadapps.com.au
news:4F86D5515B190F893D6BC69CE7C96A05@in.WebX.maYIadrTaRb...
news:
> > Hi,
calls
you
> for
item
> or
> without
> the
> to
> > be created.
> > Laurie Comerford
> > CADApps
> > www.cadapps.com.au
> > Command: _MAPCREATE
> > Command: -mapcreate
> > Command: filedia
> > Command: cmddia
> > Command: _mapcreate
: P
> > sometimes
> program
> > it
> > find
> > > Thanks.
I tried the send command, it works fine, but only one simple thing, how can
I know if a specific topology exist.
Because if I try to delete a non existent topology, the script fails.
And further, I don't think that I'll do scripting, the following works:
doc.SendCommand "_MAPTOPOADMIN" & vbCr & "d" & vbCr & "test" & vbCr &
"y" & vbCr
doc.SendCommand "_ADEATTACHDATA" & vbCr & "geo" & vbCr & "detach" & vbCr
& "all" & vbCr
Or
Cmd = "_MAPTOPOADMIN" & vbCr & "d" & vbCr & "test" & vbCr & "y" & vbCr
doc.SendCommand Cmd
C863396CCD2FDFDBF0D26D04977236A3@in.WebX.maYIadrTaRb...
> Hi Yves,
> Laurie Comerford
> CADApps
> www.cadapps.com.au
> news:
> > > Hi,
> calls
can
that
> you
process
> > for
> item
> > or
"-MAPCREATE",
> > without
of
> > the
topology
> > to
> > > be created.
> > > Laurie Comerford
> > > CADApps
> > > www.cadapps.com.au
> > > Command: _MAPCREATE
> > > Command: -mapcreate
> > > Command: filedia
> > > Command: cmddia
> > > Command: _mapcreate
: P
> > > sometimes
> > program
> > > it
can't
> > > find
> > > > Thanks.
allaire, you can also use the Create.LSP tools that is included in the C:\Program Files\Autodesk Map 2004\Sample folder
