Autolisp -HYPERLINK Syntax Help
I'm trying to generate hyperlinks to map objects for a drawing which I am going to export to dxf and link to a document to do php queries off of. I can't seem to get the -HYPERLINK syntax correct though.
This is what I am using:
(command "-HYPERLINK" "i" "o" inspt "" "" "" url acct)
The inspt is the insertion point in x,y,z form and is being read from a database. The url is the query string I'm using and the acct is just the displayed value I was trying to put in.
I cannot get this to work correct, I keep ending up with the url in the description and the description being blank. I can put "url" after the insertion point twice and it will put the url in but it comes up with a # sign in front of it and doesn't follow correctly.
Can anyone tell me what I am doing wrong or suggest another way to do this.
Thanks in advance.
The hyperlinks are stored in xdata. If you're attaching it to an entity you can do something similar to what I have below.
(if (null (tblsearch "appid" "PE_URL"))(regapp "PE_URL"))
(setq hyper_list (list (list -3 (cons "PE_URL" (list
(cons 1000 hyper_text) ; URL
(cons 1002 "{")(cons 1000 tool_tip)(cons 1002 "}") ; Tool Tip
(entmod (append (entget ename) hyper_list))
