Accessing MAP global coordinate system with VBA
Is it possible to determine the global coordinate system that a drawing is associated with? Is it also possible to get the properties of that coordiante system such as ellipsoid parameters and projection parameters?
Todd
You can get the coordinate system from the current
project by using the Project.CurrentProjection Property.  You can also get
the coordinate system from an attached drawing using
AttachedDrawing.Projection.
You can not get the coordinate system parameters
however.
Scott
Is
Todd
Hi Scott
Forgive me for being ignorant, but I can't find any reference to the Project or AttachedDrawing in the acad help system (AcadMap 5). Could you elaborate please? Thanks again.
Todd
Todd,
Within VBA you have to reference the 'AutoCAD Map
2000i Release 4.5' type library.  Also check the AcMapAtm.chm file in the
AutoCAD Map\Help directory for documentation on the API.
Good Luck,
Scott
Hi
Scott
Todd
