Hello!
Is there a way to disable the highlight (change to dashed) function when simply hovering over an entity? No command selected, just moving the crosshair around the screen. I find this extremely annoying.
Thanks!
Solved by drjohn. Go to Solution.
That turns all highlighting off. In 2016 the highlight of hatch is off by default. In 2013 hatch highlight is in the options menu somewhere - I can't remember where. I skipped 2015.
To add to the thread you can also look to this article.
How to change the highlighting of selected objects in AutoCAD
In 2018 you can do this from options menu. on bottom right of selection tab. Turn off visual effects, uncheck command preview and property preview. It worked of me. I did not need to go in setvars.
Thank you Rbax
How simple was that!!!
I tried all the other solutions - researched for hours.
The other solutions reduced the highlighting some but did not remove it.
The techs at Autodesk aught to ask you how to fix their stuff.
Thank you for the correct/easy answer.
SELECTIONEFFECT 0
PRESELECTIONEFFECT 0
SELECTIONPREVIEW 0
These work for me on an underpowered rig.
thanks for the help this preview is realy anoing because sometimes you have a big block object and it became all light and bright just by passing the mouse cursor over it, it is a pain to the eyes
