Show only
Search instead for
I have suddenly started getting this FATAL ERROR when trying to start AutoCAD. The error then closes the application completely and I am unable to use it. The error description is: "FATAL ERROR: FATAL ERROR: (0x61d30005) C:\Program Files\AutoCAD LT 2008\achapi17.dbx". This is an error that no one from support has managed to fix yet after 8 days! I hope someone out there does know. I can't re-install either because of ERROR 1606. And yes, I am logged on as Administrator.
Of course an easy solution always has a side effect! Now that the Achapi17 file is deleted, the "Properties" command doesn't work anymore! So, if you can work CAD without needing to get to the Properties, then all is well, but we know that is not the case. Back to Status = Problem with no one apparent answer. Where are the people who know stuff??
The same problem on XP Pro!
Clear reinstall and SP1 didn't resolved the issue. Autodesk recommended to delete the achapi file and repair installation, but it isn't a good solution - you can run AutoCAD only when the achapi17.dbx is deleted, but than the Properties command doesn't work.
I have no idea what's wrong.
