Message 1 of 10
01:07 PM
In one file, I have 2-3 sheets (tabs) that use the same XRef. If I want to change the name of that XRef, then I want to take it out of the file and replace it with a new XRef. The problem is when I go the Reference Box and click on 'Detach', it doesn't detach. I can erase the XRef on all tabs (sheets of my drawings) and Purge and close the file. When I come back, and try to detach again it doesn't work without deleting all tabs but one, then it detaches. Of course, then I have to recreate all my tabs again. How can I detach an XRefs from a file with several tabs?
