AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
XRef not maintaining changes in host drawing.
2 REPLIES 2
bneilsonmsi
331 Views, 2 Replies
I am having an issue with a file that contains multiple XRefs.  The scenario is as follows:
I have a "Master" drawing that I use as a template.  It contains all of my blocks, sheets, viewports, etc.  I attach a drawing via XRef, add my blocks as needed, publish, submit.
For the last three days, I have been working with an XRef file that will not maintain ANY changes.  If I turn off a layer, save the file, reopen, or reload, the layers are back on, lineweights are different, colors revert, etc.  However, if I open the file separate - not attached to my template, it appears the way I want.
I have visretain set to 0, visretainmode set to 2047, xrefoverride set to 0.  Also, setbylayer has no effect.
I have run Audit, and recover and no errors are returned.
What am I doing wrong?  I am at my wits end.
Screenshots attached for reference.
2 REPLIES 2
pendean
in reply to: bneilsonmsi
VISRETAIN set to 0 in the topmost file means the XREF(s) layer settings rule 100% of the time, not whatever you do in that top file.
Sounds like you really don't want that, you want the opposite.
VISRETAIN setting in the XREFs themselves mean nothing.
bneilsonmsi
in reply to: pendean
@pendean - Thanks.  Ended up there were some (apparently) hidden files in some of the blocks that somehow did not have my settings applied.  I had to open and edit the blocks to get every thing to work.
Technology Administrators
