Message 1 of 9
I received an existing conditions drawing from a surveyor which I do a "save-as" and re-name to convert to my standards, very typical for the clients I work for, in AutoCAD LT. As a check I xrefed in the original surveyor's drawing and it comes in in a different location in space. When I ID the same point in both drawings they are identical x,y coordinates. When I open the original file and xref in the converted file the same thing happens. Why don't these drawings come in directly on top of each other? I've attached both files; "2021_03_10_Velencia-Base 03-09-2020 CAD.dwg" is the original surveyors file and "21034.dwg" is the file I converted. Any help would be very appreciated.
