Riddle me this, O AutoCAD Gurus...
Sometimes when I insert/attach a file into model space it comes up as a relative path, which is what I prefer in most cases. Sometimes it comes up as a full path and I can change it to relative. Sometimes it comes up as a full path and I cannot change it. What's different?
There appears to be no rhyme or reason driving this variable; often I attach a file and it comes up as relative and then when I go to get a second file of the same type in the same directory, it comes up as a full path and I cannot change it to relative.
This is frustrating because I often create a new design from a copy of an old one. When I copy and rename the directory to make the new design, all the inserted/attached files that were imported as relative are fine but all the ones that came in with a full path are broken.
