XREF Fade Control
XREF Fade Control
XREF Fade Control
Can someone please help me with the command name that controls the fade effect for XREFs. Searched all thru help with every combination I could cone up with and I can't find it.
Thanks!
pendean
Community Legend
Community Legend
OPTIONS command, Display Tab, lower-right corner of the pop-up is the control: tap that HELP button on that pop-up to see if there is a command name associated with the tool you wish to use.
Thanks Dean, it used to be some long command name when it first came out.
