XCLIPFRAME linetype
XCLIPFRAME linetype
XCLIPFRAME linetype
Is it possible to change the linetype for xclipframe? I need it to be dash-dot instead of continuous line. Now I need to hide the frame and draw a rectangle with the  dash-dot linetype. I was just wondering if it is possible to skip the extra step as our organisation uses it in all the drawings we make.
steven-g
xclipframe only controls the visibility of the xclip. If you use xclip on a xref and then select the xref you can change the linetype in the properties toolpalette (you might need to alter the linetype scale depending on the scale of your drawing).
