Wrong Block Inserts
I use the classic insert feature and, by default, I do not have the explode checkbox marked, but on occasion I see it is checked. I work on a network, so a lot of people have access to the same dwg. files. Sometimes I will insert a block (let's say a 2x6), and it will insert as expected, but when I insert a 2x12, a 2x6 appears instead. If I try to insert ANY block that is not a 2x6, I always get a 2x6. I have found that this only happens if the explode checkbox is checked. In order to remedy this, I need to uncheck it, insert a block (any block) and restart AutoCAD. Is this caused by another user accessing the file and checking the box and this setting saved in the dwg file or some other cause? I NEVER check the box and this is not a situation with multiple blocks with the same name.
