Wipeout does not wipeout in Plot
My wipeout works in 2016 lt , when I upgraded the autocad lt  to 2018 , the wipeout doesn't hide anymore when I plot, Is there some configurations needed on it to hide the wipeout when I plot? Doing it in pdf is alright only when I plot it to A1
Sometimes, When you are working in Complex drawing, Wipeout does not work.
Therefore, You need to use PURGE command to reduce Drawing size.
I think that the issue is BUG!..
The other case that I think, In Layer manager If your Wipeout set Non-plotting Layer, You can't use Wipeout features in Plot.
Thanks for the info. I've resolved the problem by going into plotter references. It turns out the plotter memory is not enough and kinda old , so i have put the windrv mode in computer mode instead of printer.
