Hi @Anonymous
Welcome to the Autodesk Community!
To add to the thread.
You can also use this as a guide: System requirements for AutoCAD LT 2018
System requirements for AutoCAD LT 2018Operating System
CPU Type32-bit: 1 gigahertz (GHz) or faster 32-bit (x86) processor
64-bit: 1 gigahertz (GHz) or faster 64-bit (x64) processorMemory32-bit: 2 GB (4 GB recommended)
64-bit: 2 GB (4 GB recommended)Display ResolutionConventional Displays:
1360 x 768 (1920 x 1080 recommended) with True Color. 125% Desktop Scaling (120 DPI) or less recommended.
High Resolution & 4K Displays:
Resolutions up to 3840 x 2160 supported on Windows 10, 64 bit systems (with capable display card)Display CardWindows display adapter capable of 1360 x 768 with True Color capabilities and DirectX® 9 ¹. DirectX 11 compliant card recommended.
¹ DirectX 9 recommended by supported OSDisk SpaceInstallation 4.0 GBBrowserWindows Internet Explorer® 11 or laterPointing DeviceMS-Mouse compliantDigitizerWINTAB supportMedia (DVD)Download or installation from DVD.NET Framework.NET Framework Version 4.6
Checking back with you, post with any new updates if you need continued help on your thread.
Thanks for your time.
