Viewport Rotation bar in Autocad LT
What everyone think about to add an rotation 2D bar in Autocad LT for rotate the views to improve the workflow, alowing to slice the draw and produce (DRAW) views in 2d plan?
pendean
Community Legend
Community Legend
Once you manually enter your viewport, the commands to use are UCS (rotate around Z if yoou are in a plan view) followed by PLAN command set to the "current UCS".
Or you could try this much easier method https://knowledge.autodesk.com/support/autocad-lt/learn-explore/caas/CloudHelp/cloudhelp/2017/ENU/Au...
But... there is no SLICE feature/command in LT, that is only a feature in full AutoCAD.
Your task was good. But the point is to find or add to Autocad LT a way to rotate de view in 2D.
pendean
Community Legend
Community Legend
So.. what parameters are you looking for? details please, we cannot guess at what you want help with if we don't know the detailed information.
Experiment with the commands I listed, write down what you want as you use them, then post back.
EDIT: explore this post in the meantime https://forums.autodesk.com/t5/autocad-lt-forum/rotate-view-macro/td-p/2096000
Direct on the point, thats the solution. Thanks for atention.Plan Rotation - SolvedPlan Rotation - Solved
