using multiple units in one drawing
roblinger
Message 1 of 12
roblinger
I have a newbie question, and I can't seem to find the answer, mainly because I don't think I am using the correct wording. I came from using the old 2d drawing program AutoSketch, and what I am trying to ask is done easily in AutoSketch.
My AutoCAD LT drawings all have the units set to inches, however there are times when I need to create a line or circle/radius that is in feet and inches or millimeters. Is there a way to do this without changing the drawing units? In AutoSketch, if I needed to offset a line by 4mm, while my drawing units were set to inches, I would put my offset distance at "4mm", instead of 0.15748", and my line would be offset correctly.
I'm guessing AutoCAD LT has this same capability, but like I said, I just can't seem to find it.
Thanks in advance!
Rob
Replies (11)
Message 2 of 12
pendean
Community Legend
Community Legend
This is not Autosketch. You have to commit to a unit type first and stick with it.
Read this if you need to change the entire DWG file's units default https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/Convert-...
OR... if you only want to do this while dimensioning only do this https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2021/ENU/AutoC....
OR just convert in your head (or calculator) before you type it in for one offs.
HTH
Message 3 of 12
roblinger
lol, I guess not!
There are some really nice items that AutoSketch brought over from Drafix Cadd Professional. It was nice just entering the alternate unit's mark (', ", or mm) while in any drawing, no matter what the default unit was. Seems like it should be an easy thing to add, but I'm not a programmer.
Rob
Message 4 of 12
RSomppi
That's what everyone says that finds a limitation that they weren't expecting. SMH...
Message 5 of 12
roblinger
lol
Message 6 of 12
pendean
Community Legend
Community Legend
Sounds like you need to go back to AutoSketch then if this is a dire business need: in the meantime, if you want to offer up suggestion to Autodesk for future features in AutoCAD/LT you can do so here https://www.autodesk.com/company/contact-us/product-feedback
HTH
Message 7 of 12
roblinger
No, it's not a dire business need, just something to make my work day a little bit easier. I'm stuck with AutoCAD LT until I retire. I'll keep using my trusty Construction Master Pro Trig to make any conversions that I can't do in my head. I just find it funny that AS had such a simple solution for such a long time, and AutoCAD didn't copy that over.
Thanks for the comments guys.
Message 8 of 12
RSomppi
I think it's funny that a non-programmer is criticizing a premier program and it's developers.
BTW, Revit will draw with alternate units when specified.
Message 9 of 12
roblinger
Good to know about Revit.
And I wasn't criticizing the development team, I just found it odd that AutoSketch, produced by AutoDesk, had such a great simple way of entering a different "on-off" unit of measurement into a drawing.
And you are right, I am not a programmer, just like millions of other AutoCAD users out there, but I guess that means that I can't ask a simple question and then give an opinion?
Message 10 of 12
RSomppi
Oh, you're one of those people.
Did I say you couldn't give an opinion?
I'm not sure how you can make a distinction between the company and the developers in this aspect but, hey, that's just me.
Message 11 of 12
roblinger
Thanks again guys.
Message 12 of 12
roblinger
Thanks for the link, I just finished suggesting it.
