I have circled the spots that I am trying to trim. When I do the trim command it will trim the line, but not to the intersection of the circle. It keeps the line a little longer. This is very frustrating and seems like it should be something obvious.
Thanks for any help!
Solved by pendean. Go to Solution.
Could it be that your line smoothing is set too small? that is when you see the circle it is made up of a series of lines - not a smooth circle. Then when you see the line you see the true length but the circle seems to be behind your trimmed line.
Go to Options, look at the Display tab, and then look at "Display resolution". there is an "Arc and circle smoothness setting and a "segments in a polyline curve" setting. Play with the Arc and circle figure and see if it helps. Mine is set to 1000.
Hi Everyone
Thanks for your help and comments. However, I still am not able to fix this. I agree with the last post. When I zoom in VERY close it extends past the circle (see attachment). I am just working around it for now, but this has come up a couple times in the past so thought I would check here for a possible solution.
Thank you.
That is interesting. Now it looks like like it doesn't touch the circle (see attachment). I have never used REGENALL before.
